ᐅ How can IKEA Hemnes furniture be easily painted?
Created on: 20 Oct 2021 19:37
Tubapu
Tubapu
20 Oct 2021 19:37
Hello everyone, I would like to paint my IKEA Hemnes furniture – specifically a few dressers and nightstands – to give them a fresher look. I understand that Hemnes furniture is usually made of solid pine wood with a lacquer or wax finish. Now my question is: How can these pieces be painted easily but still professionally and durably, without the new paint peeling off early or looking unattractive? What preparation steps are important, which materials work best (e.g., special primers, types of paint), and are there any tips for sanding or drying times? I would appreciate a detailed guide or practical advice based on experience to successfully complete my project.
anken
20 Oct 2021 21:02
A structured approach is essential when painting Hemnes furniture. First, thoroughly clean and degrease the existing surface. Since Hemnes is often already painted, I recommend lightly sanding with fine-grit sandpaper (220 grit) to improve the adhesion of the new paint. Important: completely remove dust after sanding, ideally using a tack cloth.
Next, it is best to apply a primer that is specifically suitable for wood and previously painted surfaces. This ensures a better bond between old and new layers. For the paint, I recommend water-based acrylic paint, as it is low odor and provides a durable finish. Always lightly sand and remove dust between paint layers.
Finally, apply at least three coats and allow each to dry thoroughly (usually 12 to 24 hours depending on the product). A well-ventilated environment and consistent temperatures are beneficial for the results.
KUDAISY
21 Oct 2021 08:16
I am happy to provide a step-by-step guide that often works well:
- Clean the furniture thoroughly: remove dust, grease, and any old wax residues with a suitable cleaner.
- Sanding: preferably use an orbital sander with grit between 180 and 220 to roughen the surface gently, not to sand it down completely.
- Remove dust: carefully wipe off dust particles with a damp cloth or tack cloth.
- Priming: use an adhesion primer, especially designed for smooth, painted surfaces (e.g., acrylic-based).
- Light sanding: after priming, sand lightly with grit 320 and remove dust again.
- Painting: apply several thin coats of acrylic paint; allow each coat to dry thoroughly.
Common mistakes include applying paint too thickly and not allowing enough drying time between layers. These often cause peeling. Also, avoid cleaning with aggressive solvents, as they can damage the surface.
taudi
21 Oct 2021 11:44
KUDAISY schrieb:
Typical mistakes are applying paint too thickly and not allowing enough drying time between coats.
That sums it up very well. I would like to add that using quality brushes or foam rollers has a huge impact on the finish. Cheap tools often leave visible brush marks or air bubbles.
Additionally, you might consider treating the surfaces with a fine abrasive pad before priming. This ensures optimal adhesion without unnecessarily damaging the substrate.
Regarding the painting itself: consistent strokes and a well-conditioned room (not too cold, not too humid) are important for an even result. Patience is key – it’s better to apply several thin coats than one thick one.
If you have any questions about this, I’m happy to provide specific product recommendations.
