ᐅ How can Ikea HEMNES furniture be customized with individual colors?
Created on: 16 Jan 2019 18:27
rubysiHello everyone,
I recently purchased some Ikea Hemnes furniture and am now considering how to customize the color to better express my personal style. Since the standard Hemnes colors are often quite neutral and classic, I would like to know what options are available to creatively and permanently change the color of these pieces.
I am particularly interested in the following points:
- Which types of paints and finishes are recommended for Hemnes made of pine wood?
- How can the surfaces be prepared to ensure good adhesion and prevent peeling?
- Are there any tips for techniques to create effects like shabby chic, vintage look, or even modern textured surfaces?
- What mistakes should be avoided to ensure the process is successful and the furniture looks good in the long term?
I look forward to your experiences and recommendations, as this topic has been on my mind quite a bit lately. Thank you!
Hello rubysi,
That’s a very good question you asked! Especially with HEMNES furniture, which is usually made from painted or veneered pine wood, proper surface preparation is really crucial for achieving the best results when applying paint.
First, I would recommend lightly sanding the surfaces depending on whether they are already painted or not (grit 180-220) to improve the adhesion of the new paint. It’s best to use fine sandpaper or a sanding sponge for this.
For the paint choice, acrylic paints or special chalk paints are good options as they can often be applied easily and provide a pleasant, matte finish. If you want a particularly durable and smooth surface, water-based varnishes with good coverage would be more suitable. Also, keep in mind to apply a protective topcoat (e.g., clear varnish or wax) after painting to prevent the paint from wearing off quickly.
Regarding techniques:
- For a shabby chic look, you can selectively sand areas with fine sandpaper or steel wool after painting to create a “worn” effect.
- Chalk paints are also great for creating vintage or distressed looks because they are easy to work with.
- If you want a modern, textured surface, you can experiment with texture paste or similar materials and then varnish over them.
It’s important to thoroughly remove dust after each intermediate sanding and consider using a bonding agent or primer, especially if the surface is very smooth.
Common mistakes include sanding too roughly, insufficient cleaning before painting, or not using a protective topcoat.
In summary: Take enough time for the preparation and try out small test areas before treating the entire piece of furniture.
I hope this already helps you!
batabe schrieb:
First, I would recommend lightly sanding the surfaces, depending on whether they are already painted or not (grit 180-220), to improve the adhesion of the new paint.I’d like to add a small note: in my experience, it’s worth carefully considering whether sanding the original painted surface of a HEMNES piece is really necessary.
Ikea usually uses fairly smooth paint finishes, so light sanding can help the new paint adhere. However, before sanding, I would check if applying a special primer is possible – sometimes that’s enough and you don’t need to roughen the surface as much.
Also: chalk paint is often recommended, but it’s not always very durable if you plan to use your furniture heavily!
I think it makes sense to opt for modern acrylic paints with appropriate sealers for frequently used items, even if it requires a bit more preparation and time. This way, you get long-lasting results that won’t disappoint you in the long run.
It would also be interesting to hear if anyone has experience with spray paints on HEMNES, as this method often results in a very even finish.
What are your thoughts?
karus66 schrieb:
I think it makes sense to use modern acrylic paints with suitable sealers for heavy use, even if that means a bit more preparation and time.Thank you for your input, karus66! I find the combination of durability and individual color design particularly interesting. Honestly, I was a bit concerned that acrylic paints might seem too "cold" and inflexible compared to chalk paints.
What has your experience been like? Do you have any tips on the after-treatment? For example, how many coats of paint should be applied, and which type of sealer would you recommend?
Also, how do you approach applying a light color over darker wood? Is a simple primer sufficient, or do you need to use a special covering paint?
My main concern is that the final result not only looks great but also withstands everyday wear and tear in places like the kitchen or living room without issues.
rubysi schrieb:
How is it going for you? Do you have experience with the post-treatment? Specifically, how many coats of paint should be applied, and which type of sealant would you recommend?I’m happy to provide some more detailed advice here – the topic of customizing the color of Ikea HEMNES furniture is really interesting and can be optimized with a structured approach:
1. Preparation:
- Clean the furniture thoroughly and lightly sand it (grit 180-220) to remove any gloss.
- Remove dust, preferably with a damp cloth or a special dust removal tape.
- If the surface is very smooth or you are applying a completely different color, use a bonding primer specifically designed for wood.
2. Priming:
- When applying light colors over dark wood, always use a white or neutral primer.
- This significantly improves coverage and reduces the number of paint layers needed.
3. Painting:
- Use high-quality water-based acrylic paints – these are durable and low in odor.
- Apply 2-3 thin coats with a good brush or foam roller to avoid brush marks.
4. Sanding between coats:
- Lightly sand with fine sandpaper (grit 220-320) to achieve smooth surfaces.
- Afterwards, remove dust thoroughly.
5. Sealing:
- For furniture surfaces that see heavy use, I recommend a high-quality clear coat (matte, satin, or glossy, depending on preference).
- Alternatively, furniture wax can be used for protection, which adds a soft tactile finish.
Summary:
- Generally, 1 coat of primer, 2-3 coats of paint, and at least 1 coat of sealant are recommended.
- For surfaces with heavy use, apply 2 coats of clear varnish.
What to avoid:
- Applying paint too thickly or unevenly.
- Not allowing sufficient drying time.
If you want a shabby chic look, after the last sanding you can opt for sealing with wax and use less clear coat.
Good luck customizing your HEMNES furniture!
