ᐅ How can Ikea HEMNES furniture be custom painted to achieve a personalized color finish?
Created on: 16 Sep 2024 09:17
Leo40
I am considering painting some of my IKEA Hemnes furniture pieces in custom colors to better match my interior design. I would like to know which preparation steps are recommended to properly prepare the surfaces of the Hemnes furniture for painting. Additionally, I am interested in which types of paint adhere best and are suitable for the relatively hard MDF material used in the Hemnes range, without the paint chipping or becoming unattractive after a short time. Does anyone have specific experience or recommendations on how to proceed in order to achieve not only a good aesthetic result but also a durable finish? I am especially interested in how to handle the typical pre-painted surfaces of Hemnes furniture.
likuken
17 Sep 2024 14:07
I always find it fascinating how many DIY enthusiasts believe that a bit of sandpaper and some cheap paint can turn an IKEA piece of furniture into a designer item.
GiRoyce schrieb:
Water-based acrylic paints are well suited because they dry quickly, have low odor, and do not apply too thickly.
Sure, but let's be honest: if you really want a customized, durable finish that won’t peel off after a year, you can’t avoid using a two-component (2K) paint. It’s more expensive and requires more effort, but the result is definitely much more professional.
Also, if I were you, I would consider alternative surface treatments: dip-coating or vinyl wrapping instead of just a few coats of paint.
Just a thought: not every paint attempt actually improves the piece of furniture. Often, the original texture and charm that characterize Hemnes get lost.
tra_nina
18 Sep 2024 09:51
Here is an objective summary on painting IKEA HEMNES furniture individually:
- The furniture is typically made of solid pine with MDF components, some of which are painted.
- Cleaning and removal of grease are essential before sanding.
- Sanding serves to roughen the surface and ensures adhesion.
- Using a bonding primer improves the connection between old paint layers and new paint.
- Water-based acrylic paints are well-suited; they have low odor and are flexible.
- For heavily used surfaces, two-component (2K) paint is more durable but requires special handling (mixing and ventilation).
- Brushes leave more texture, which can support a certain country-style look; rollers or spray guns result in smoother surfaces.
- Light sanding between coats (grit 320) is standard to ensure a smooth finish.
This procedure ensures an aesthetically pleasing and long-lasting paint finish.
Jensson
18 Sep 2024 11:42
In addition to the practical tips, I would like to highlight some common mistakes I often see when repainting HEMNES furniture:
- Mistake 1: Sanding too coarsely. This can roughen the pores of the wood and later cause uneven color. Fine-grit sandpaper (180-220) is recommended here.
- Mistake 2: Applying paint too thickly. The result is a sticky or cracked surface. Thin layers that dry thoroughly are better.
- Mistake 3: Skipping the primer. Without this step, the new paint layer often peels off.
- Mistake 4: Working in a dusty environment. Dust on wet paint leads to unsightly unevenness.
My advice: Schedule enough time for each step and regularly check the result once it is dry.
