ᐅ How can IKEA HEMNES furniture be adapted or modified for a children's room?
Created on: 8 Sep 2020 08:23
bofusanHello everyone, I am currently looking into how to adapt the IKEA Hemnes furniture series specifically for children’s rooms to make it more functional, safer, and better suited for kids. The HEMNES furniture is generally quite sturdy and offers many possibilities thanks to its classic construction, but I am specifically searching for ideas and experiences on how to modify wardrobes, dressers, or shelves so they better meet the needs of children. For example, I am thinking about rounded edges, additional anti-tip fittings, modified interior layouts for toys or clothes, and maybe simple alterations that allow the furniture to grow with the child. I am especially interested in practical tips or guides that can be implemented with basic tools, without having to replace the entire piece of furniture. Has anyone here ever made such modifications to HEMNES furniture or have ideas that have proven effective? Thanks in advance!
Hello bofusan, I find your question very specific and helpful. Regarding the modification of HEMNES furniture for a children's room, I can share some practical tips based on my own experience. Basically, I recommend fitting all visible edges and corners of the furniture with flexible plastic edge protectors; this is simple and prevents injuries. For storage, adjustable shelves have proven effective, as they can be easily repositioned when needed—allowing the furniture to adapt as the child grows. Adding anti-tip devices (such as wall anchors) is also essential, since the cabinets can easily tip over if children climb on them or play nearby. Changing the interior layout, for example by installing additional drawer inserts or fabric bins, helps create more order and clarity.
In addition to the points already mentioned, I would like to add that for HEMNES furniture—especially dressers and cabinets—weight and stability play a crucial role. Therefore, if modifications are made, it is important to consider the structural load capacity. For example, it is not advisable to make too many additional drill holes during modifications, as this can weaken the wood structure. A common modification is to replace a swing door with a drawer front to make access easier for younger children. In this case, high-quality slides and hinges are important to maintain durability. Furthermore, the use of child-friendly handles—such as those without sharp edges that are easy for small hands to grip—is recommended.
I would like to focus on material processing and surface finishing. The HEMNES series is made from solid pine wood, which is generally well-suited for post-treatment. A very effective method is sanding the surfaces to round off edges, reduce hazards, and make the wood smoother. Afterwards, I recommend applying a child-safe furniture wax or linseed oil treatment to preserve the natural appearance while better protecting the surface against dirt and moisture. This can be done at home with minimal tools and results in durable furniture that also creates a warm atmosphere in the children’s room.
edisondan8 Sep 2020 14:12To add to the previous explanations: Another way to make HEMNES furniture more functional is by installing lighting elements, such as LED strips on the interior walls of shelves or cabinets. Children especially benefit from better visibility, particularly in deep shelves or behind doors. These lighting systems can also be connected to motion sensors if needed, helping to keep energy consumption low. Besides the physical modifications, this makes the use of the furniture more user-friendly. Another option is to modify the furniture modularly, for example by unscrewing a top section of a cabinet to adjust its height appropriately for different ages.
sonplo schrieb:
Regarding the modification of HEMNES furniture for the children’s room, I can share some practical tips that I have personally implemented. Thank you for the advice, especially concerning the edge protectors and the adjustable shelves. I am also interested in which materials you used for the adjustable shelves. Are these compatible with standard wood panels, or do they require special cuts? How about the mounting—are there recommended solutions that maintain stability? The issue of tipping prevention seems crucial as well; are there general recommendations for the HEMNES series on which types of fasteners work best?Similar topics
