ᐅ How can Ikea Hemnes furniture be better protected against wear and tear?
Created on: 3 Oct 2024 08:47
PIMEO37
PIMEO37
3 Oct 2024 08:47
I own several pieces of furniture from the Ikea Hemnes series and have noticed that these items tend to show wear and tear relatively easily in everyday use, especially in high-contact areas like table edges or dresser surfaces. This raises the question: how can Hemnes furniture be better protected against wear without significantly altering its appearance or having to undertake extensive restoration work?
I am particularly interested in practical protective measures or care tips that go beyond regular cleaning, such as special sealants, protective films, or surface treatments that are not very noticeable at first glance but provide significantly greater durability to the furniture.
Are there any experiences with suitable products (wood oils, varnishes, etc.) or mechanical protective solutions? I look forward to your assessments and suggestions!
Palenar
3 Oct 2024 11:12
Hello PIMEO37,
I would like to go into detail about how to effectively protect Hemnes furniture from wear, both mechanically and by treating the surface.
First, I would recommend different protective layers depending on how heavily the furniture is used:
- Clear varnish or polyurethane coatings designed specifically for wood surfaces provide lasting protection. It is important to choose a finish that matches the color and texture of the wood to preserve the typical Hemnes look.
- For heavy use, an intermediate layer of wood oil or hard wax oil is advisable. This offers natural care and penetrates deeply into the wood. Afterward, a protective topcoat of varnish can be applied.
For application, a fine brush or a soft cloth is recommended, applying several thin layers with short drying times to avoid blistering.
For mechanical protection, thin, transparent furniture protection films can be applied to highly used areas. These are hardly visible and protect against scratches.
Additionally, furniture pads can be attached underneath the legs to prevent abrasion and scratches on the floor, which indirectly increases stability.
Finally, it is important to maintain the furniture with regular cleaning while avoiding aggressive cleaning agents.
I would also be interested to know if your furniture is placed in humid rooms in particular or if moisture is generally a factor, as this influences the choice of surface treatment.
tra_nina
4 Oct 2024 09:36
Hello PIMEO37,
Palenar’s approach is technically very sound, and I would like to add some specific recommendations:
- For the Hemnes furniture, I recommend using a transparent, matte acrylic-based furniture varnish. These varnishes are resistant to scratches and moisture, dry quickly, and hardly change the surface texture.
- Alternatively, a special furniture care paste can be used, which preserves the surface and fills in small micro-scratches.
- Avoid aggressive cleaning agents or alcohol, as they can roughen the surface.
- A preventative solution is to place felt or rubber pads under objects to prevent pressure marks and scratches.
- For tabletops, so-called table protectors or mats made of transparent plastic are also suitable; they are unobtrusive and very durable.
- When applying varnish, I recommend ensuring good ventilation in the area and thoroughly cleaning and dusting the furniture beforehand.
Keep in mind: Protection should be proportional to usage; excessive protection can alter the furniture’s appearance or increase maintenance effort.
If you would like specific product recommendations, I can gladly provide some.
koduga
5 Oct 2024 14:29
I think this topic is really important because many people don’t realize how delicate the Hemnes series can be, even though it appears quite sturdy.
tra_nina schrieb:
For the Hemnes furniture, I recommend applying a transparent, matte acrylic-based furniture lacquer.
I find this advice very good because it preserves the look while providing protection that isn’t too intrusive. I would just add that the preparation needs to be done very carefully – I once tried a can of lacquer without properly preparing the wood, and it resulted in unpleasant bubbles on the surface.
I have also had positive experiences with felt pads on the feet, especially if the furniture is moved around frequently or if there are small children at home. This helps prevent scratches on both the floor and the furniture caused by friction.
I’m also curious if anyone has tried alternative sealing methods, such as beeswax or special furniture waxes? I often have doubts about whether these are really suitable for Hemnes or more appropriate for solid wood finishes.
Thanks to everyone for the helpful tips. I’ve noticed that with a few additional measures, you can achieve a lot.
