I plan to furnish my small bedroom with furniture from the IKEA Hemnes series, but I am facing challenges due to the limited room size. The classic HEMNES pieces like the bed, wardrobe, and nightstand are visually appealing and of good quality, but they do take up quite a bit of space, which can be problematic in smaller rooms.
So my question is: How can IKEA HEMNES furniture be adapted or configured for small bedrooms to be both functional and space-saving without losing style or comfort? Are there clever modifications, specific combinations, or tips for optimizing space with HEMNES, perhaps even custom adjustments or additions?
I look forward to your experience and advice!
Hello MANPAR,
I find your question very interesting because HEMNES is indeed a series that, despite its rather classic design, can be well adapted for small spaces.
First of all, you should consider which pieces of furniture you really need. For example, the HEMNES bed is quite solid, but there are also models with storage compartments underneath that provide optimal storage space under the bed—this saves you additional storage in the room.
Another tip: use HEMNES dressers as storage solutions that you can also use as nightstands. This way, you combine several functions in one piece of furniture.
Additionally, you can visually lighten the furniture by painting it or using darker shades to create contrast—this often makes them feel less "space-filling."
Finally, sometimes it helps to combine HEMNES furniture with open shelving systems to create an airy feel and visually enlarge the room.
If you like, you can describe your room in more detail (dimensions, window, door positions), and I can assist you more specifically.
Hello MANPAR and everyone interested,
I would like to take a deeper technical look at this topic, as it often fails in the details when it comes to customizing furniture for small spaces.
First, it is important to measure the exact dimensions of the bedroom precisely, including windows, doors, and radiators, to place the furniture accurately. IKEA HEMNES furniture is relatively standardized, so a modular approach makes sense.
- Adjusting the height: The classic HEMNES bed has a taller headboard. There is an option to sand down or replace the back panels to make the space feel more open.
- Multifunctionality: Adding extra shelves in HEMNES dressers or removing the bottom drawers creates more breathing room and saves space for other items.
- Custom modifications: It is often recommended to modify the wardrobe section, for example by fitting it with half doors or sliding doors to ensure free movement within the room. This approach, however, requires advanced carpentry skills.
- Color choice and surface finish: White or light shades reflect light better and make small rooms look larger. HEMNES is typically finished with a white glaze, which can be an advantage in small spaces.
A direct question for you: Are you already using HEMNES furniture that you want to redesign, or are you planning a complete new purchase? This is important to know how much effort or investment you are prepared to make.
kaubi schrieb:
A direct question for you: Are you already using HEMNES furniture that you want to modify, or are you planning to buy new pieces entirely? This is important to understand how much effort or investment you are willing to make.This is a very relevant point. From a practical perspective, I would add that adapting HEMNES furniture for a small bedroom works best if you already have some pieces. In that case, it is advisable to first sketch the room layout and then optimize the storage space.
- For bedrooms under 10 square meters (about 108 square feet), multifunctional furniture with built-in storage is ideal. A HEMNES bed with a storage box is perfect here.
- Custom work such as modifying cabinet doors is only recommended if you have the appropriate craftsmanship skills and can affect the furniture system.
- Alternatively, using low-height HEMNES dressers combined with additional wall shelves can create a more open and airy feeling.
- A consistent color scheme with light tones enhances the sense of space.
I therefore recommend prioritizing function: storage, sleeping area, freedom of movement, and then design, to achieve the best adaptation of the HEMNES set.
