ᐅ How can IKEA Hemnes beds be equipped with additional features?
Created on: 14 Jun 2017 08:37
fadil62Hello everyone,
I am planning to upgrade my IKEA Hemnes bed with additional features, as the standard version does not fully meet my needs in terms of storage and comfort. Specifically, I am interested in what options are available to enhance this model through custom modifications such as integrated lighting, USB charging ports, improved drawer organization, or even an electric adjustment for the sleeping surface. The goal is to add functionality without damaging the original structure or compromising stability.
Has anyone had experience with similar modifications on Hemnes beds? What craftsmanship considerations should be kept in mind, and which materials or accessories would you recommend? I am also interested in how to integrate a modern comfort feature, such as smart control for lighting or charging ports, with minimal effort.
I look forward to your tips and suggestions!
Hello fadil62,
regarding your plan to add extra features to IKEA Hemnes beds, I recommend focusing first on the storage options. The original drawers can be made more efficient with simple shelves and dividers. This way, you can make the best use of the available space.
Furthermore, I see great benefits in integrating USB ports into the bed frame or headboard. Often, a slim cable duct can be installed to hide the wiring and help avoid cable clutter. You can work very modularly here, so the bed’s stability is not affected.
I would only recommend electric adjustments if you are prepared for major modifications and possibly significant changes to the bed’s construction. This carries the risk of compromising the structural integrity.
Finally, a tip about lighting: LED strips with adhesive backing are ideal for discreetly attaching to the bed frame. Together with a smart LED controller, you can control the lighting very flexibly.
I hope these tips assist you with your project.
REN40 schrieb:
Integrating USB ports into the bed frame wall or headboard.From a functional perspective, this is often the most practical approach, as modern devices increasingly require multiple charging points in the bedroom.
In addition to REN40’s points, I recommend using high-quality, certified modules with overload and short-circuit protection when integrating USB charging ports. Cheap components not only compromise safety but can also damage connected devices.
For better drawer organization, custom-made dividers made of wood or plastic are advisable. These should fit precisely and be securely installed. This increases durability and prevents items from mixing when drawers are opened.
Regarding lighting, broad, diffuse LED lighting is preferable to spotlights to create a pleasant atmosphere. LED panels or flexible strips with dimmer functions work well for this purpose.
Electric bed adjustment is a complex challenge. Unless you have experience in electromechanics, DIY modifications are not recommended. Professional solutions often include special frames and drive systems that are not designed for the Hemnes style.
Conclusion: A combination of optimized storage, modern and safe electrical components, and smart lighting is the most practical solution.
fadil62 schrieb:
Does anyone have experience with these or similar modifications on Hemnes beds?Hi fadil62! So you want to give your Hemnes bed a bit of an upgrade, right? Sounds great – I love it when you can turn simple furniture into something really cool!
I replaced the standard lighting on my Hemnes with smart LEDs that you can control via an app. Having soft lighting at night without turning on the main light is really valuable – and the effort was manageable since the LED strips are self-adhesive and can be cut to size.
I also installed a small shelf on the headboard side, perfect for your phone and charging cables. For USB connections, I use a power bank, which keeps cable management flexible and convenient.
Electric adjustment is a whole different level; I’d definitely recommend buying pre-made systems for that. But for storage, there are great organizers for the inside of the drawers, so you can keep everything neat and easily accessible.
It sounds like a fun little project, and with some DIY enthusiasm, you can achieve a lot! If you need more tips, I’m happy to exchange ideas.
