ᐅ How can the Ikea Hemnes furniture be reinforced for heavier use?
Created on: 29 Nov 2017 08:37
Clemens38
Clemens38
29 Nov 2017 08:37
Hello everyone, I have a question that has been on my mind for a while: How can an IKEA Hemnes wardrobe be secured and reinforced so that it remains stable even under heavier use—such as when it holds a lot of weight or is opened and closed frequently—without wobbling or getting damaged? I am thinking of possible reinforcements, additional wall fixings, or modifications to the construction. It would be helpful if anyone has experience with practical solutions or suitable materials to ensure the functionality and durability of this relatively delicate-looking piece of furniture under greater load. Thanks in advance for your tips!
SINEL
29 Nov 2017 09:14
I would first check and reinforce the wall mounting. Especially with Hemnes, the wall attachment is crucial for stability. Additional brackets or stronger screws can work wonders. Also, check the screws at the joints and tighten them if necessary.
V
valerie-tr
29 Nov 2017 11:53
Basically, the Hemnes wardrobe, made of solid wood, is sturdy but not designed for very heavy loads. For improved stability under greater stress, I recommend the following measures:
- First, replace the included wall fasteners with stronger metal brackets, preferably with at least 3-4 attachment points to better distribute the load.
- At the rear joints and corners of the wardrobe, additional wooden dowels or screws can be used to connect the panels more securely. Be sure to pre-drill carefully to avoid splitting the wood.
- The bottom of the wardrobe should ideally have an additional strip or profile to better distribute the load onto the floor and prevent warping.
- Pay attention to potential tensions in the wood type and workmanship, especially in humid rooms.
I am also interested in how exactly the wardrobe will be used. Are there particularly heavy items or frequent opening, which increase the load? Depending on the usage, reinforcements can be adjusted.
Clemens38
29 Nov 2017 12:37
valerie-tr schrieb:
I’m still interested in how exactly the usage looks like. Are there particularly heavy items or constant opening that increase the load? Depending on the use, reinforcements can be adjusted.
Thank you for the detailed reply. Exactly, both apply. I store relatively heavy books and binders inside, which together weigh about 30-40 kg (66-88 lbs). In addition, there is frequent opening and closing, including by children. The stability should therefore not only hold up in the short term but remain durable over time, without screws loosening or the wood being damaged. I also want to avoid the cabinet becoming unstable or wobbly at some point.
sonplo
29 Nov 2017 15:22
The combination of high load and frequent use primarily requires secure anchoring. In addition to stronger metal brackets for wall mounting, I would recommend also fixing the cabinet to the floor, if possible. This helps prevent wobbling or tipping. Additionally, the shelves should be reinforced with metal supports or replaced with thicker wooden boards to prevent sagging.
JUHAU
30 Nov 2017 08:19
Additional screws at the connection points almost always help. The original wall plugs are sometimes too weak. Additionally, use pull-out resistant anchors or metal brackets at critical points.
