ᐅ How can the IKEA Hemnes series be modernized in a DIY project?
Created on: 3 Sep 2023 18:27
Sauplo
Sauplo
3 Sep 2023 18:27
I would like to start a discussion on the topic "How can the IKEA Hemnes be modernized in a DIY project?" I own this classic piece of furniture, which impresses me on one hand with its quality and timeless style, but on the other hand feels somewhat outdated today—especially in modern living environments. My idea is to give the Hemnes a fresh, contemporary look through my own hands-on work, without completely losing the character of the piece or compromising its stability. Perhaps surface treatments, new handles, inlays, or even structural modifications could be used. I am particularly interested in which materials and techniques make sense, how to protect and update wood, and what pitfalls to watch out for during such a DIY makeover. Does anyone have experience or suggestions on the best way to effectively update the Hemnes?
Nathanaelk
3 Sep 2023 19:43
This topic is really interesting, especially since the Hemnes, due to its sturdy construction and classic appearance, is often used as a base for DIY projects. When updating it, I would proceed in several steps, paying close attention to thorough preparation and material compatibility:
- First, completely disassemble the piece of furniture if possible, to better treat the surfaces.
- Sanding: The paint or varnish must be fully removed or at least sanded down until matte. An orbital sander with fine grit is a good tool for this, otherwise hand sanding is needed in hard-to-reach areas.
- Surface treatment: Modern coatings based on water can be chosen to ensure an environmentally friendly and less harmful application. Alternatively, colored oils or wax treatments can be used to highlight the wood grain.
- Replace handles: Metal handles with clean lines (e.g., matte black or brushed metal) often create a minimalist, contemporary look.
- Extra features: Inlays with painted surfaces, for example in concrete effect or colored melamine panels, add depth and contrast.
Finally, it is important to always keep drying times and the compatibility of layers in mind to avoid cracking or poor adhesion. I would be interested to hear how much experience you have with surface treatment in a DIY setting and what tools you have available?
SONLIS
4 Sep 2023 09:16
I would like to add that when modernizing the Hemnes, the importance of material quality and proper application is often underestimated. The success of a fresh coat of paint largely depends on thorough preparation. Additionally, I recommend taking extra care with white or light-colored Hemnes models, as the wood can be damaged by aggressive sanding.
Replacing the handles is also a very effective yet simple step that makes a difference both visually and in terms of touch. It is advisable to purchase handles with an exact fit to avoid new drilling, which helps maintain the piece’s aesthetic appeal and stability.
Upgrading with lighting — such as LED strips inside drawers or behind the cabinets — can also be an interesting addition, reflecting the current trend towards indirect lighting. This combination of design and function is especially beneficial for DIY projects.
Ethan
4 Sep 2023 14:02
Nathanaelk schrieb:
Surface treatment: Modern paints can be water-based to ensure an environmentally friendly and less harmful application.
I find this especially important to emphasize because many people, especially in DIY projects, choose cheap but pollutant-rich paints and then wonder about unpleasant odors or allergic reactions.
Additionally, I want to add that when sanding, you should handle the rounded edges of the Hemnes carefully to avoid damaging its distinctive profile. If you're unsure, using a fine sanding sponge is a good option.
Replacing handles is a really good tip. Stainless steel or matte black finishes are particularly recommended as they are easy to clean and durable. Those willing to invest a bit more time can also fill old drill holes and create new ones to make something completely new.
Are there already any specific ideas about preferred colors or styles?
Layla
5 Sep 2023 11:38
Ethan schrieb:
Are there already specific ideas about preferred colors or styles?
I think that’s a very important point. The renovation should not only suit the furniture pieces themselves but also fit the overall room design.
A friend of mine transformed his Hemnes with a matte dark gray paint and minimalist black metal handles, which created a very calm and modern atmosphere in the room—while the warmth of the solid wood remained visible thanks to a clear lacquer that still shows the grain.
I believe such a project also says a lot about personality and style, so I recommend thinking carefully about color schemes, material combinations, and future use beforehand.
How do you manage the time and effort factor with such a renovation? Some DIY projects can quickly get out of hand or become stressful.
