ᐅ How can the Ikea HEMNES be cleaned quickly and easily?
Created on: 6 Sep 2021 08:23
benta
Hello everyone, I have been using the IKEA Hemnes wardrobe for some time and have noticed that the surface gets dirty quickly due to dust and fingerprints. I’m interested in how to clean the IKEA Hemnes quickly and easily. It’s important to me that the method is as gentle as possible on the surface, as I don’t want to risk any damage or discoloration. Which cleaning products and techniques do you recommend that are practical for everyday use and don’t require much preparation? Thanks in advance for your tips!
pikin
7 Sep 2021 12:33
I agree with Genevieve, here are some clear facts:
- IKEA itself recommends using mild water with a small amount of dish soap for Hemnes lacquered furniture.
- Neutral cleaners or special water-based furniture cleaners are suitable; avoid stronger chemicals such as alcohol, acetone, or ammonia.
- Household remedies like vinegar or citric acid should not be used regularly due to their acidic pH, as they can damage the lacquer layer.
- For quick cleaning, a damp microfiber cloth is usually sufficient, followed by drying the surface.
These recommendations are intended to preserve the longevity of the finish.
benta
8 Sep 2021 06:47
pikin schrieb:
Home remedies like vinegar or citric acid should not be used permanently due to their acidic pH, as they can damage the paint layer.
Thank you for this clarification! I had actually considered using vinegar for cleaning because I am familiar with it from other areas. It’s good to know that I should avoid it with HEMNES.
Is there a quick way to specifically remove fingerprints? I notice that the smooth surface picks them up quickly, and they always remain visible. Should I use a special product for this, or is just water plus a dry microfiber cloth already the best option?
EDWARD0
8 Sep 2021 14:21
Mild dish soap diluted in water on a microfiber cloth often does the trick. Important: Don’t make the cloth too wet and wipe dry afterward.
For more stubborn fingerprints, a water-based glass cleaner can help, but use it sparingly and test on an inconspicuous area first.
