ᐅ How can the Ikea Hemnes be best utilized in a home office?
Created on: 1 Nov 2023 08:13
Simon-us
Hello everyone, I’ll start this thread with the following question: How can the Ikea Hemnes furniture range be best used in a home office to create a functional, ergonomic, and at the same time comfortable working environment? I’m considering combining the Hemnes series for desk, shelving, and storage – especially because I find the classic designs very appealing – but I want to avoid it becoming impractical. Do you have any tips on the optimal layout, storage use, and maybe ergonomic adjustments to keep in mind when using Hemnes? Which combinations have been tested, particularly if you spend a lot of time working at the computer and want to keep documents easily accessible? Looking forward to your experiences and suggestions!
Simon-us
2 Nov 2023 10:12
angel schrieb:
A simple option is to place small, sturdy wooden blocks under the table legs, which can be stacked to achieve the desired height.
This is exactly what I’m looking for. Thank you! Are there any experiences regarding stability and safety? I want to make sure that the tabletop doesn’t wobble or become unsafe under load.
lyndon
2 Nov 2023 10:44
As long as the wooden blocks are made of sturdy material and placed evenly under each table leg, this solution can be very stable. It is important that they are properly secured or prevented from slipping – for example, with foam rubber or anti-slip pads. This will help avoid wobbling.
Alternatively, there are professional adjustable table legs that can be mounted under the Hemnes table, although this option requires more effort.
Jeanbar
2 Nov 2023 11:22
The safety of the construction is, of course, essential, especially when spending extended periods at the workspace. Many DIY enthusiasts also simply use adjustable furniture feet or table legs from hardware stores that can be attached to the existing Hemnes table.
Another tip: complement the workspace with suitable desk pads and cable organizers to further enhance comfort and ergonomics.
bauku
2 Nov 2023 12:02
The top part is made of wood, I built it myself 😊. The stability is excellent; I use thick boards and screws. The tabletop doesn’t wobble at all when everything is securely fastened. It’s really enjoyable to work this way because you can adjust the height individually! Definitely a great DIY project that’s worth it.
Simon-us
2 Nov 2023 12:37
bauku schrieb:
The extension is made of wood; I built it myself
Thanks for the inspiration! Do you perhaps have any plans or dimensions you could share? I’d be very interested in learning how to actually build something like that.
Jeanbar
3 Nov 2023 07:11
Simon-us, if you don’t want to make something like that yourself, I recommend designing the furniture sections to be modular. This makes later adjustments easier. You might also find a carpenter who can produce suitable wooden attachments at a reasonable price.
The Hemnes design is classic, so recreating it is relatively straightforward if you are familiar with woodworking.
On the topic of ergonomics: Always make sure your elbows are at about a 90° angle when typing and that the screen is at eye level, oriented toward natural daylight. This is essential for healthy working in a home office.
