ᐅ How can the Ikea HEMNES furniture be adapted for elderly people?
Created on: 12 Sep 2024 08:37
Lefola
Hello everyone, I would like to start a discussion on the topic: How can Ikea Hemnes be better adapted for older adults?
The HEMNES range is popular, but I see some challenges when it comes to use by elderly people, especially regarding shelf height, drawer handling, and furniture stability. Older adults often have limited mobility, reduced strength, and need more safety in daily life.
How could the design and functionality of this product be specifically improved to make it more accessible and comfortable for seniors? I am thinking of ergonomic adjustments, modified dimensions, and possibly additional assistive features.
Please share your experiences, ideas, and technical considerations – I look forward to a variety of approaches!
Dilen
13 Sep 2024 09:57
I would like to go deeper into detail-oriented design, especially since simple solutions are rarely available.
- Material choice: Instead of Canadian pine wood (as used in Hemnes), surfaces with antibacterial properties and easy-to-clean finishes, such as melamine-coated surfaces, would be more suitable for elderly people.
- Mechanics: There are advanced drawer slides with force-assist features, for example, electrically assisted drawer runners or spring systems that require minimal effort.
- Modularity: A modular, adjustable furniture system where either height or handle positions can be changed without needing to replace the entire unit would be practical. This means components could be reordered and swapped out.
- Lighting: Built-in LED strips in the furniture could help with orientation and are a useful addition for people with impaired vision.
In conclusion: How much should such customization cost? Ikea is known for affordable solutions, but when it comes to senior-friendly equipment, individual adaptations are often more expensive.
tra_nina
13 Sep 2024 13:11
The following modifications have been highlighted in studies and professional literature as particularly effective for senior-friendly furniture:
- Clear, simple operating mechanisms with leverage
- Handles with a minimum diameter of 5 cm (2 inches) or approximately 10 cm (4 inches) in length to increase the gripping surface
- Avoidance of heavy doors or drawers; instead, sliding components
- Stability measures to prevent tipping, such as wall anchoring with adjustable brackets
- Adjusted heights for seating and storage surfaces, since joints in seniors often have reduced mobility
These measures are generally compatible with HEMNES but may require minor design adjustments. An ergonomic evaluation of prototypes with seniors or senior representatives is recommended before offering mass-produced models.
Ramon4
14 Sep 2024 08:26
Lefola, this topic is important, especially because furniture in everyday life is often simply not adapted to the needs of older users.
Regarding dressers and cabinets, the following points are worth mentioning based on my experience:
- Handle angle: A handle that lies flat or is too close to the frame significantly delays opening. A bar handle or one with an angled lever makes pulling easier.
- Sliding properties: Drawers should ideally work with soft-close mechanisms and at the same time offer low friction resistance. The HEMNES models could be updated with high-quality full-extension slides.
- Accessibility: Interior design with pull-out shelves, possibly combined with drawers, can help minimize bending and stretching.
Width is also a factor: Older people often use mobility aids (walker, wheelchair), so the movement space around the furniture should be adapted. Adjusting the floor plan in the living area can be beneficial for this.
juMira46
14 Sep 2024 20:13
Who would have thought that a HEMNES wardrobe has so much potential? 😄 But seriously: the combination of safety, comfort, and easy-to-use features would be the key.
I imagine a HEMNES in a ‘senior-special edition’: Larger handles with a rubber texture, maybe even magnetic openings so that no physical effort is needed. Plus a few built-in LEDs to light the way when it’s dark.
And of course, stability with extra base panels or wall mounts. You could almost say: comfort and safety wrapped in wood. The perfect piece of furniture for grandma and grandpa that even designers in care homes wouldn’t shy away from!
Would anyone like me to sketch this idea as a concept for the thread starter? 😉
