ᐅ How can IKEA Brimnes furniture be used for storing heavy items?
Created on: 6 Aug 2016 18:23
Bomo43Hello everyone,
I’m currently looking into how to effectively use IKEA Brimnes furniture for storing heavy items. I plan to store mainly larger and heavier things—such as tools, heavy books, or various household appliances. I’m especially interested in how much weight each module can actually hold and if there are any recommended tricks to make the furniture more stable or to better distribute the load.
I’m also considering whether modifications or reinforcements (for example, additional shelves, support braces, or other DIY adjustments) are really worthwhile or if they might compromise the IKEA design.
Perhaps you have experience using Brimnes dressers or shelving units with loads heavier than usual? I’m also curious about the long-term durability, particularly if the furniture is filled to capacity daily.
I’m looking forward to useful tips, ideas, or even critical opinions so I can make a well-informed decision!
Bomo43 schrieb:
I am also interested in the long-term durability, especially if the piece of furniture is used heavily on a daily basis.Brimnes is solid for moderate loads. For very heavy items, you need reinforcement with additional panels at the bottom or on the back.
Reinforcements are usually necessary if the furniture is subjected to frequent heavy loads.
Hello Bomo43,
Regarding your question about using IKEA Brimnes furniture for storing heavy items, I would like to offer some advice.
First of all, the Brimnes range can carry a reasonable load, but the typical capacity is around 15-20 kg (33-44 lbs) per drawer or shelf. Exceeding this limit risks damage to the rails or panels.
Therefore, I recommend:
- First, check which model you have and refer to the official maximum load capacity.
- Use stronger materials or thinner metal sheets as drawer bases to better distribute the weight.
- Rely on the back panel as an important stabilizing surface. If it is missing or not fully covering the back, the furniture may tip over or become unstable.
- If possible, reinforce the furniture with brackets on the inside to prevent sagging.
If you really need to store heavy items (more than 20 kg (44 lbs) per drawer), it is advisable to secure the furniture to the wall and distribute the weight across multiple compartments.
I hope this helps. If you have any more questions, feel free to ask.
JEREMIAH387 Aug 2016 19:46dopite schrieb:
If you really want to store heavy items (more than 20 kg (44 lbs) per drawer), it would be advisable to secure the furniture to the wall and distribute the weight across several compartments.I can only agree with that. I once had issues myself because I tried to stack tools in Brimnes drawers, which simply aren’t designed for that. Eventually, one drawer bent, causing a lot of frustration.
What I learned from this is to put less weight in each drawer and reinforce wherever possible. Attaching the furniture to the wall especially gives me peace of mind, especially with small children in the house.
I fully understand your concerns and hope you find a solution that is stable and safe.
