ᐅ How can IKEA Brimnes furniture be protected from UV light?
Created on: 13 Jun 2021 08:17
nabameo
I have several IKEA Brimnes furniture pieces in a room that unfortunately receives a lot of direct sunlight. I have noticed that the UV light is already causing early signs of wear on the surface, such as slight fading and minor discoloration. Since the furniture is made of coated wood and MDF, I am wondering what practical measures are available to protect Brimnes furniture from UV radiation over the long term. I am interested in both mechanical solutions (e.g., protective films, covers) and chemical treatments (e.g., special paints or sealants).
I want to protect the furniture with minimal impact on its appearance and am primarily looking for effective methods that can be easily implemented at home. Maybe you have recommendations, unusual experiences, or warnings about what to avoid?
How can IKEA Brimnes furniture be protected from UV light? I look forward to your opinions and tips!
Joshbe
14 Jun 2021 12:15
Basically, when dealing with IKEA Brimnes furniture, keep in mind that the surfaces are made of melamine-coated particleboard or MDF, which are sensitive to UV light. Chemical protection is limited because applying finishes can alter the surface appearance and sometimes may not adhere permanently.
The most effective protection is mechanical, using UV-protective window films. High-quality films block almost the entire UV spectrum (UV-A and UV-B), reducing the main cause of premature aging and fading.
If that is not enough, a UV-stable furniture varnish would be advisable. Choose a tested, water-based varnish with a clear, matte finish. Multiple thin layers provide better protection than one thick layer.
Avoid aggressive or solvent-based products to prevent damage to varnish and plastic parts.
A combination of UV film and a clear varnish is recommended.
Additionally, dust your furniture regularly and avoid using aggressive cleaners, as dirt can increase UV exposure through scattering.
bauku
15 Jun 2021 09:34
Super interesting topic! I also have my Brimnes furniture in a room with a lot of sunlight and did the following:
- Applied UV protection film to the windows myself. With a bit of patience, it was quite easy!
- For particularly exposed furniture surfaces, I applied a clear, very thin protective film, like the kind used for tablets or car windshields – slightly transparent but with UV protection.
For me, this is a great combination. The furniture still looks great, and I basically have immediate, effective UV protection. Also, make sure to regularly use blinds or curtains to reduce direct sunlight when needed.
Just give it a try, and you’ll quickly notice how much it helps. I’m really happy with this solution! 😊
