ᐅ How can Ikea Brimnes furniture be protected from sunlight?
Created on: 2 Aug 2018 09:12
milan2
milan2
2 Aug 2018 09:12
I recently bought some IKEA Brimnes furniture (cabinets, dressers) and want to protect them as best as possible from direct sunlight. My issue is that the furniture has a dark finish, and I’ve noticed that exposure to sunlight near the windows causes them to fade quickly or damages the surface.
I’m interested in knowing which methods or materials you would recommend to effectively protect the Brimnes furniture from UV radiation without negatively affecting the appearance or functionality (e.g., drawers). For example, are special UV-protective window films useful, or are there suitable furniture care products that can protect the surface?
Additionally, I would be curious if anyone has experience with alternatives like specialized furniture covers, window blinds, or other measures that can slow down the aging process.
Thanks in advance for your input!
toril
2 Aug 2018 10:05
Hello milan2,
Your concern about protecting IKEA Brimnes furniture from sunlight is valid, as UV radiation can indeed cause fading and deterioration of painted veneers.
For effective UV protection, I primarily recommend a combination of the following measures:
- UV protection window films: Special thin films can block up to 99% of UV rays, are transparent, and only minimally affect natural light.
- Interior blinds or curtains: Especially if they are blackout or UV-blocking.
- Furniture care with clear protective coatings or UV-resistant waxes: These enhance the long-term durability of surfaces, but should be matched to the furniture material.
You should avoid harsh cleaning agents or heavy coverings that might trap moisture.
A combination of window film and regular maintenance provides the most sustainable protection. This approach preserves the appearance and does not impair the furniture’s functionality.
I hope these tips help you further.
Henry
2 Aug 2018 11:47
I understand your problem well, milan2, as I had a similar issue with my furniture. The slow fading of the surface is especially frustrating because you only really notice it over time.
From my experience, one thing I learned is that window film alone is not always enough, especially when the sun shines on one spot for a long time. Often, blinds or at least curtains are helpful to physically block the radiation.
It is also important to occasionally rearrange the furniture or slightly change its position so that the same areas are not constantly exposed.
I have had mixed experiences with furniture care products—some make big promises that I can’t fully confirm. However, I would still recommend trying a care oil or furniture wax to make the surface more resistant.
I hope this helps you and that you find a good solution!
klabe
2 Aug 2018 14:03
Hello milan2 and everyone interested,
I would like to contribute a brief step-by-step guide on maintenance and UV protection for Brimnes furniture, so you can systematically apply the most important measures:
1. Check windows: First, determine how intense and how long sunlight reaches your furniture.
2. Choose window films: Use UV-blocking films. These are usually available at home improvement stores or furniture stores and can be cut and applied yourself. They are transparent and do not affect the appearance.
3. Additional shading: Combine the film with blinds or rollers that you can lower during the day depending on the sun’s position.
4. Use suitable furniture care products: Make sure the products are suitable for lacquered surfaces and do not contain strong solvents.
5. Clean surfaces properly: Use a mild, damp cloth without aggressive chemicals.
6. Move furniture: To reduce constant direct exposure, occasionally move the furniture slightly if possible.
Common mistakes on this topic:
- Skipping window films and only covering the furniture (risk of moisture buildup)
- Using aggressive cleaning or care products
- Leaving furniture exposed to direct sunlight permanently without protection or ventilation
Summary: UV-protective window films, appropriate shading, and proper furniture care are the best ways to prevent fading and surface damage on Brimnes furniture.
neoren
2 Aug 2018 16:32
briefly and to the point: UV protective films on windows are the best way to prevent fading. Additionally, furniture wax can be used to protect the surface. Blinds or roller shades are a good complement when the light is too strong.
batabe
3 Aug 2018 08:49
Good morning milan2,
I would like to add that, besides direct UV protection, indoor humidity also plays an important role. Low humidity rooms, especially in summer with windows tilted open, can dry out furniture surfaces and make them more vulnerable.
The following points are advisable:
- Window films or curtains to block UV rays
- Regular ventilation, but avoid allowing moist air to settle on the furniture
- Possibly light furniture care using products that contain moisturizing components without leaving oily residues
This helps prevent rapid wear or cracks in the finish of Brimnes furniture and provides longer-lasting protection.
