Hello everyone, I own several Ikea Brimnes furniture pieces, mainly dressers and nightstands. Unfortunately, I have increasingly noticed that the surfaces and edges of the furniture are prone to scratches. This is especially frustrating because the white surfaces seem quite delicate. My question is: What proven methods or materials are available to effectively protect Ikea Brimnes furniture from scratches without affecting the appearance? I am interested in both preventive measures and tips for maintenance or repair of minor scratches. Thank you in advance for your experiences and advice!
To effectively prevent scratches on Ikea Brimnes furniture, I recommend the following: - Use protective films or clear acrylic protective sheets on the surfaces - Attach felt pads or plastic bases under decorative items or electronic devices - Clean regularly with non-abrasive cloths to remove dirt particles that could cause scratches when moving items These measures largely prevent mechanical damage without altering the appearance.
zartra schrieb:
I think using furniture wax or special touch-up markers to repair small scratches is worthwhile.I can only agree with that. Additionally, coasters for glasses and pots help prevent scratches caused by abrasion and moisture.
Hello Nekiano, I would like to elaborate a bit more on this topic, as it is very important to me personally. Ikea Brimnes furniture usually has a coated surface that is unfortunately quite sensitive to scratches and abrasion. It is important to protect the furniture with soft materials during transport and daily use, and to handle it carefully.
Here are some tips:
- Apply protective films designed specifically for furniture surfaces; these are transparent and hardly affect the appearance.
- Use spacers or felt pads under decorative items, lamps, or other objects placed on the furniture.
- Avoid placing sharp-edged or rough objects directly on the surface.
- Always use coasters during typical household activities, especially under glasses and pots.
If scratches do occur, I recommend:
- Carefully retouching with furniture wax in a matching color
- For larger damage, consider using a suitable paint marker
Also, make sure to clean only with mild, lint-free cloths and avoid aggressive cleaning agents to prevent further damage to the surface.
In summary, careful handling combined with simple protective measures is the best approach.
Here are some tips:
