ᐅ How can IKEA Brimnes furniture be updated with a modern paint finish?
Created on: 15 Jan 2021 10:37
Nonadelina
Nonadelina
15 Jan 2021 10:37
Some time ago, I purchased several IKEA Brimnes furniture pieces and am now considering how to modernize them with paint to better fit a contemporary interior style. My main question is: which types of paint or painting techniques work best for the typical materials used for Brimnes furniture (mostly particleboard with melamine coating or similar)? I am also interested in how to best prepare the surface to ensure the new paint adheres well and is durable. Are there specific priming methods or intermediate sanding steps that are particularly recommended? Additionally, I would like to know if you have experience with different finishes or effects (matte, satin, high gloss, chalk paint, etc.) that suit modern furniture well. Overall, I want to avoid the furniture looking cheap or artificial after painting. I look forward to detailed tips and shared experiences.
letar
15 Jan 2021 11:12
For modern refinishing of IKEA Brimnes furniture, proper surface preparation is essential. The furniture is usually made of particleboard with a melamine resin coating, which is very smooth and has low absorbency. A good primer base is crucial here:
- Thoroughly clean and degrease the surface (e.g., with isopropanol)
- Lightly sand with fine sandpaper (grit 180-220) to roughen the surface
- Use a primer, especially adhesion primer for smooth surfaces (acrylic or synthetic resin primer)
Afterwards, uneven areas can be filled with putty. Painting is recommended with acrylic paints (water-based) for easy application and environmental friendliness, or with polyurethane paints for high durability. The finish (matte, satin, high-gloss) depends on personal preference; matte or satin looks more modern and subtle, while high-gloss appears more sophisticated but more noticeable.
Chalk paint can be an interesting option because it requires minimal preparation, but it is less durable and needs sealing.
In general, it is important to apply several thin coats, sanding lightly between each coat, to achieve a good result.
fiman
15 Jan 2021 12:05
First, sand the melamine surface, then spray it with a primer. After that, you can paint it with matte finish acrylic paint. Lightly sand between coats. This ensures good adhesion and gives a modern look.
BeAndrea
16 Jan 2021 08:47
Nonadelina schrieb:
I am also interested in how to best prepare the surface so that the new paint adheres well and remains durable.
This is a very important point! For Brimnes furniture, which has a melamine coating, lightly sanding with 180 grit is often not enough because the surface is very dense. I recommend a combination of mechanical and chemical roughening:
- First, lightly sand the surface with fine-grit sandpaper,
- Then possibly treat it with a suitable adhesion promoter (adhesion primer spray),
- Use a high-quality, synthetic resin-based primer,
- After drying, sand lightly again and then carefully apply the paint.
letar schrieb:
Chalk paint can be interesting since it requires little preparation, but it is less durable and needs sealing.
I can confirm that: If you choose chalk paint, you should definitely seal it with wax or clear varnish; otherwise, the surface will wear quickly. This is especially important for furniture used daily.
Have you considered whether you prefer a completely smooth or rather a slightly textured finish? Sometimes a slight texture can also highlight a modern look.
bupar
16 Jan 2021 10:22
fiman schrieb:
First, sand the melamine surface, then spray with a primer.
In addition to this process, I would like to emphasize that choosing the right sandpaper is crucial. Sandpaper that is too coarse can unnecessarily damage the surface. Fine-grit sandpaper around 220 grit is ideal.
Furthermore, selecting the appropriate primer is essential. There are special adhesion primers for melamine boards that not only improve adhesion but also ensure even paint absorption.
letar schrieb:
Apply several thin coats, lightly sanding (fine grit) between each coat
This results in a smooth and durable finish. It is also recommended to use high-quality brushes or a spray gun to achieve a streak-free result.
Nonadelina
17 Jan 2021 09:53
BeAndrea schrieb:
Have you considered whether you prefer a completely smooth or a slightly textured finish?
Thank you for the detailed explanation! I am leaning towards a matte or satin finish that appears as smooth as possible but doesn’t look too sterile or cold. A slight texture would be acceptable as long as it maintains a modern feel.
Does anyone have experience with how matte acrylic lacquer surfaces behave when cleaning? I want my furniture to be low-maintenance and resistant to daily wear.
Also, I’m wondering whether it’s necessary to fully disassemble the furniture before painting or if it’s sufficient to just work on the surfaces, such as drawer fronts or side panels?
