ᐅ How can Ikea Brimnes furniture be adapted to be pet-friendly?
Created on: 23 Jul 2024 08:17
Rubenbau
Some time ago, I bought several IKEA Brimnes furniture pieces, mainly dressers and cabinets, and now I am focusing more on how to make these furniture items better suited for pet owners. Since furniture often gets scratched by cats and dogs, and there can be issues with stability, access, or usability, I am interested in the options for specifically modifying or adapting the Brimnes pieces.
I am particularly interested in ideas and practical experiences regarding
- scratch resistance (e.g., surface treatments),
- pet safety (e.g., no sharp edges, secure doors),
- storage design for pet supplies,
- integration of retreats or sleeping areas directly in or on the furniture,
- and possibly tips on how to reduce pets’ tendencies to scratch the furniture.
Who has experience with IKEA Brimnes furniture in combination with pets? Are there clever modifications or recommended accessories? I look forward to detailed answers and practical advice!
Ramon4
24 Jul 2024 08:54
Good morning everyone,
I would like to add that alongside mechanical protective measures, knowledge of the material is also important.
Brimnes furniture is usually made from coated particleboard, which gives the surface a nice appearance but is also sensitive to scratches and moisture.
For households with pets, I would recommend:
- Using a primer or a protective film with high abrasion resistance
- Avoiding placing the furniture in direct sunlight, as the coating can be damaged by UV exposure and cat claws
- Securing shelves well wherever possible to prevent parts from coming loose when pets jump on them
It might also be worth considering a special furniture upgrade directly from Ikea. There are now accessories available that can be used.
And last but not least, regular furniture maintenance and injury prevention for pets should go hand in hand.
Dilen
24 Jul 2024 11:13
I would like to take the discussion further from a technical perspective, as I see some additional aspects in this area.
The Brimnes series uses MDF or particleboard with a melamine coating, which creates a smooth surface, but the scratch resistance is limited.
Here are some points I would address:
- Material enhancement: Adding a layer of HPL (High Pressure Laminate) could significantly improve scratch resistance. However, this is a more complex modification and requires sawing or precise cutting of the panels.
- Use of ventilation grilles: For recessed spaces behind doors, instead of just drilling holes, it is better to install small metal ventilation grilles to ensure optimal air circulation while maintaining security.
- Structural reinforcements: Standard joints are often made with dowels and screws; these should be reinforced internally with metal brackets, especially for cabinet flap mechanisms, as many pets tend to climb.
- Surface treatment: Sealing with a thin layer of polyurethane varnish can help, but it is only somewhat environmentally and pet-friendly. Bio-certified options should be chosen here.
My question would be: Which pets should the furniture be most resistant to? Cats, dogs, or perhaps rodents? The requirements vary greatly depending on scratching behavior and activity levels.
Rubenbau
25 Jul 2024 07:47
warrenka57 schrieb:
I’m curious if you are also struggling with the issue of stability?
Thanks for the suggestion, yes, that was indeed a concern for me. Especially when the cats jump on the shelves or climb up the side panels, I worry that the furniture might give way. That’s why I’m interested in reinforcements or additions that can improve stability.
Dilen schrieb:
My question is: What type of pets should the furniture mainly withstand?
I basically have two cats that are very agile, like to jump on furniture, and scratch quite strongly. Therefore, I am looking for a combination of scratch protection and increased durability.
What I’ve read so far in the thread sounds very helpful, especially the ideas with scratch mats and ventilation grilles. Are there any tips on how to apply the films smoothly without bubbles or tears? I have found that to be a challenge so far.
klo61
25 Jul 2024 09:34
Hello Rubenbau,
here are a few tips that can help when applying the film:
- Thoroughly clean and dry the surface of the furniture beforehand
- Cut the piece of film to size in advance, leaving it slightly larger
- When applying, use a squeegee or a similar flat plastic card to push air bubbles outwards from the inside
- If bubbles remain, carefully prick them with a needle and then smooth out the film
Regarding stability: Reinforcing the interior of the furniture with additional metal brackets is often the best solution. Suitable brackets can be found at hardware stores, and they can be easily screwed in without affecting the appearance.
Don’t hesitate to invest in these small extras during the process; they make a difference in the long run.
