ᐅ How can Ikea Brimnes furniture be made child-safe?
Created on: 19 Mar 2018 09:43
TOFIKO
TOFIKO
19 Mar 2018 09:43
I have several Ikea Brimnes furniture pieces at home, including wardrobes and dressers, which I now want to childproof as my toddler is becoming more mobile. Specifically, I am interested in effective and practical ways to make the Brimnes series safe for children without significantly reducing the furniture’s functionality.
My main concerns are:
- That wardrobes or dressers could tip over
- That the child could get injured on locked or sensitive areas
- That drawers or doors don’t open too easily
Does anyone have tips for installing safety locks, especially for Brimnes, or do you know of alternative methods to secure this furniture well? Perhaps experience with specific child safety devices or additional anchoring?
It is important to me that the measures are solid and truly provide safety, not just a half-hearted solution. Thanks in advance for your suggestions!
matskeo
19 Mar 2018 10:11
I would definitely secure the furniture to the wall. Brimnes often has less stable legs, so it can tip over easily. Additionally, you can buy child safety locks for drawers that simply clamp between the cabinet body and the drawer front.
Tevin
19 Mar 2018 11:26
Hello!
Generally, you should first secure the furniture to prevent tipping. Ikea offers suitable wall anchors for the Brimnes series, which you can fix into the wall using wall plugs. This helps avoid the furniture tipping over if a child pulls or climbs on it.
For doors and drawers, there are various child safety locks available. A proven type are magnetic locks, which are installed on the inside. These prevent children from opening the compartments on their own, while adults can still easily open the furniture.
If you don’t want to use magnetic locks, clamp or latch variants are recommended. They are easy to install and do not require removing any parts of the furniture.
Another common solution is removing handles, if the furniture design allows it, or using so-called screw locks.
If you need further assistance, please feel free to ask!
Danabla
20 Mar 2018 07:52
A structured approach to childproofing Brimnes furniture involves the following steps:
- First, secure the furniture to the wall using the specially designed wall anchors provided. The Brimnes series typically comes with a wall anchor that should always be used. If none is included, purchase appropriate, sturdy anchors.
- There are two main options for securing doors and drawers: magnetic child locks or mechanical locks. Magnetic systems are less noticeable and integrate better visually, while mechanical locks are easier to install.
- It is important to ensure that neither screws nor the installation of safety devices compromise the function and stability of the furniture.
- Optionally, corner protectors and edge guards can be installed, since Brimnes furniture features hard edges where children might get injured.
- Additionally, regularly check that all safety devices remain securely in place and have not been loosened by children’s play.
Together, these measures provide a high level of safety without restricting usability.
LANICOLE
20 Mar 2018 09:18
Danabla schrieb:
First, secure the furniture to the wall using wall anchors designed specifically for this purpose.
Exactly, this should always be the first step. Additionally, I recommend installing a soft-close mechanism or at least drawer stoppers if the drawers slide very smoothly. This helps prevent small children from pinching their fingers or the drawer swinging open uncontrollably.
Tevin schrieb:
Magnetic locks mounted inside
I have had very good experiences with these myself; they are invisible and do not affect the appearance. The only drawback is that you always need to have the magnet key on hand for adults to open the drawers.
Also, narrow edge protectors on the front corners can help, especially with furniture like Brimnes that has rather sharp edges.
One final tip: since Brimnes is relatively lightweight, it is especially important to secure it carefully to the wall, preferably using anchors suitable for the wall material (e.g., cavity wall anchors for drywall).
This way, your kids will be as safe as possible!
risar
21 Mar 2018 12:37
TOFIKO schrieb:
That cabinets or dressers could tip over
This is the most important point: furniture tipping is the main cause of injury among children. Always use the included anti-tip devices from Ikea.
matskeo schrieb:
Buy child safety locks for drawers that simply clamp between the cabinet and front panel.
These are quick to install and very effective for Brimnes, as the furniture fronts are often quite smooth.
An additional tip: if your child likes to open drawers or doors, sometimes securing them with simple hook-and-loop tape can help if you don’t have fixed locks. It’s not quite as secure as proper latches, but better than nothing.
Finally, make sure to regularly check that the safety devices are still working and show no damage. Regular inspections are important because children’s behavior changes as they grow.
I recommend combining these points to create a fully secure living environment.
