I am planning to renovate my IKEA Brimnes furniture with minimal effort, as I want to modernize the design without replacing entire modules or starting complex carpentry work. Specifically, I am interested in simple methods and materials that are practical for updating or enhancing the surface, handles, or small imperfections. Does anyone have practical tips on how to quickly and easily improve the Brimnes, for example, using appropriate paints, films, or by replacing certain parts? It would also be helpful to know whether the surfaces can be sanded or painted well and what technical aspects I should consider to ensure the renovation is durable and the furniture remains stable.
The surface of the Brimnes modules is generally melamine-coated, which means that traditional sanding like on real wood is hardly possible without damaging the coating. Therefore, when it comes to painting, I recommend using special primers designed for melamine-coated surfaces to ensure good adhesion.
- Thoroughly clean and degrease the surfaces before painting.
- Apply a primer, for example, a bonding primer from a hardware store, that is specifically suitable for plastics and melamine-coated furniture.
- Then paint with acrylic or acrylic-based paint.
Alternatively, self-adhesive furniture film is an option, available in many designs and can be removed residue-free if needed. This is especially useful if you want to quickly give the piece of furniture a completely new look.
A small tip for changing handles: The handles can be easily replaced if you bring the appropriate screws. This way, you can achieve a modern update with minimal cost and effort.
nubar schrieb:
The surface of the Brimnes modules is generally melamine-coated, which means that traditional sanding like on real wood is hardly possible without damaging the coating.That’s exactly what I wanted to emphasize. The material is quite sensitive to mechanical treatments like sanding. It is important to use a good primer; otherwise, the paint will not adhere permanently.
Additionally, you can work with small details to create a fresh look:
- Replacing the handles with matte black or gold-colored variants.
- Applying adhesive film inserts on the doors or drawers if you cut them carefully.
- Dark felt pads or bases on the feet also change the overall appearance.
If you want to keep it minimalistic, you can simply remove the doors and stick foil on the inside of the drawer fronts; this is reversible and quick to do.
GiRoyce schrieb:
Additionally, you can work with small details to create a fresh look:I would like to go much deeper here, as a high-quality and durable renovation requires several considerations that are rarely taken into account.
First: The melamine-coated surface is very smooth and non-porous. Therefore, it is essential to roughen the surface before any paint application or adhesive work. This can be done carefully using very fine sandpaper (e.g., P240) to improve adhesion. Be careful not to remove too much material, as this will damage the coating.
Second: The right primer is mandatory. Regular primers usually are not sufficient because they cannot permanently overcome the low surface energy of the melamine coating. Specialized adhesion promoters or epoxy primers are recommended if durability is important to you.
Third: For the actual finish, very hard-curing paints, preferably acrylic or polyurethane-based, are suitable. Apply several thin layers and lightly sand between coats.
Fourth: If you plan to change the handles, pay close attention to the exact positioning of the drilled holes – in Brimnes furniture, for example, these holes are often standardized, but the material thickness is low, and over-tightening screws can easily cause tearing. In such cases, I recommend using washers or wood glue for stabilization.
Additionally, a note: If the renovation is not only meant to look nice superficially but also to remain mechanically stable, avoid using foil that is too thin without protective layers. It’s worth investing in quality to enjoy the furniture over the long term.
Before you start, one question: How extensive is your renovation planned to be? Often, delicate updates are sufficient, or are you aiming for an almost complete surface transformation?
