ᐅ How can Ikea Besta be used most effectively as storage in the hallway?
Created on: 19 Feb 2020 14:23
GALEN37
GALEN37
19 Feb 2020 14:23
I would like to start a discussion on the following topic: How can the Ikea Besta system be used most effectively as storage in a hallway? My hallway at home is relatively narrow, about 3.5 meters (11.5 feet) long and just under 1.2 meters (4 feet) wide. Storage space is generally limited, especially for shoes, jackets, bags, and smaller everyday items like keys or umbrellas.
The Besta system offers many options with modular cabinet units and additional doors or drawers. It is important to me that the solution remains as slim as possible to avoid overcrowding the hallway, while also being practical for quick access.
I am especially interested if anyone has experience with modular setups of Besta, which height and depth combinations work well, and whether it is useful to include complementary items like wall hooks or storage boxes.
Ideas on using the top surfaces (e.g., shelves, seating) and organizing the interiors (partition systems, baskets) would also be very helpful to make daily use more efficient.
I look forward to your tips, experiences, and critical feedback if the Besta system might not be suitable for hallway use. Thanks in advance!
Nils58
19 Feb 2020 15:47
Hello GALEN37!
Great that you’re addressing the topic of hallway storage with Besta – the system is really versatile and makes organizing fun! 😊
I also have a Besta combination in my hallway and can share a few tips:
- Choose rather low modules, for example 38 cm (15 inches) high and 40 cm (16 inches) deep, so the hallway doesn’t feel cramped.
- Use the shallow drawers for smaller items like keys, chargers, or gloves. This way, you have everything under control and nothing lying around.
- Very important: opt for closed doors to create a tidy look! Especially in the hallway, you don’t want everything visible.
- On the top shelf, you can place a decorative basket for hats or bags.
I also chose hook rails next to the Besta to quickly hang jackets – this combination makes good use of space without feeling cluttered.
In general: don’t be afraid to experiment. Besta is flexible, and you can always add or change elements later. Good luck, and feel free to ask if you have more questions!
naujon
20 Feb 2020 10:38
Hello GALEN37,
If you want to make efficient use of Besta in the hallway, it’s worth looking at the system as a modular unit with several possible uses. I’ll explain step by step:
1. Module size and structure:
- The standard depth of Besta (40 cm / 16 inches) is usually sufficient for hallways, as it doesn’t take up too much space.
- I wouldn’t choose a height greater than 64 cm (25 inches) for hallways to maintain an open feel.
- Stacking several lower modules on top of each other can create a practical seating area or shelf.
2. Internal organization:
- Drawer inserts for small items (e.g., keys, tools) help keep things organized.
- Fabric baskets or boxes can be stored flexibly and pulled out when needed.
3. Add-ons:
- Hook rails or magnetic strips on the side offer additional hanging options without opening the cabinets.
- LED lighting can brighten up the hallway design and improve orientation.
4. Practical use:
- Shoes fit well in open shelves; antibacterial shoe boxes or ventilation are recommended.
- Seasonal items can be stored above the cabinets.
Please avoid overcrowding the hallway by using a minimalist color scheme and choosing lots of white or light tones for the Besta system.
Summary: Besta works well in hallways if you limit the height, organize storage smartly, and use outer surfaces multifunctionally. Feel free to ask if you have any questions!
GUSTAVO56
21 Feb 2020 09:02
Hello GALEN37,
to discuss the topic in a more technical and detailed way, I will address several aspects of using Besta in the hallway:
- Structural stability and weight: Since Besta units can be used as wall or floor furniture, it is especially important to ensure stability in the hallway, as seating areas are often used there. I recommend placing heavier units at the bottom and securing taller assemblies either by connecting the modules together or fixing them to the wall.
- Choosing optimal dimensions: A depth of 40 cm (16 inches) is standard. For narrow hallways, shallower tops can also be used, for example, by combining Besta as a base with narrow shelves mounted on top. The width is very flexible, with 60 or 120 cm (24 or 47 inches) widths being commonly practical.
- Interior organization: There are drawers, doors, and shelves available. For different items, it is advisable to equip drawers with flexible divider systems. For shoes, there are practical drawers with perforated fronts that allow ventilation while keeping dust out.
- Expansion options: Those who want to use the space above the Besta system can add additional units. In the hallway, combining it with stools as seating that fits into any niche also works well.
- Appearance and function: Matte or glossy fronts can make the hallway appear smaller or larger. White or light colors create openness, while dark fronts make the hallway feel more compact with the same surface area.
Finally, I would like to ask: What is the ceiling height in your hallway, and are you planning to include seating options there? This will help to tailor the ideal Besta configuration precisely.
I look forward to your feedback!
