Hello everyone, I am currently planning to customize my Ikea Besta shelving unit by using fabric fronts instead of the usual wooden or glass doors. The fabric should be stretched tightly and remain durable over time, without sagging or looking unattractive. I am particularly interested in practical methods, which materials and fastening techniques are best suited for this, and what important factors I should consider during the process. Has anyone had experience with mounting fabric fronts on Ikea Besta units of various sizes? I look forward to expert tips and practical advice!
One proven method is to glue a narrow frame edge made of thin plywood onto the Besta door, which protrudes slightly and serves as the mounting surface for the fabric frame. This way, the fabric frame can be easily removed without damaging the original door.
For the frame material, spruce strips from a hardware store are the most cost-effective choice, with a smooth sanded surface to prevent the fabric from getting pinched or damaged.
It is also important to use strips with the correct dimensions for the frame so that the hinges still close flush and nothing jams.
poted schrieb:
Also keep in mind that children often touch the fronts, so washable or at least wipeable surfaces make sense.Exactly, and for situations like that, fabrics with a water-repellent coating are a good option, as they can be easily wiped clean with a damp cloth. Look for upholstery fabrics with protective features – you’ll find a wider variety of attractive colors and patterns, perfect for a custom-designed Besta.
Additionally, you can attach small magnetic fasteners to the back of the frame. This way, the fabric fronts can be easily removed for washing or changing without needing to undo screws or staples.
Thanks to everyone! The advice regarding the frame dimensions and fastening with screws from the back is very helpful.
Are there any issues with the Besta hinge inserts in this setup? Could the thick battens possibly push them out too far, causing the doors not to close properly?
Of course, I don’t want to modify the doors only to end up with hinges that don’t work.
Are there any tricks to avoid this problem while still achieving a stable frame for the fabric?
Or are there other mounting systems I might have overlooked? I look forward to any additional tips.
Drilon1 schrieb:
Are there any issues with the Besta hinge inserts? Could the thick frames potentially push them too far outward, causing the doors not to close properly?Yes, that is a valid concern. The standard Besta hinges are designed for flat doors, and adding a frame about 2 cm (0.8 inches) thick can indeed affect the door’s closing function. The solution is to use so-called screw-on hinges with adjustable mounting plates from furniture construction, which allow fine adjustments in multiple directions.
Alternatively, you can dimension the frame so that it minimally overlaps the door panel in depth, with the fabric surface applied overlapping. This way, the functional height of the hinge is maintained.
Furthermore, repositioning the hinge’s base plate may require slight trimming or reworking. This is easier with solid wood frames; with coated Besta doors, you should be careful not to damage the surface.
bupar schrieb:
The solution is to use so-called screw-on hinges with an adjustable backplate from furniture making; these allow fine adjustment in multiple dimensions.Thank you, that makes sense to me. I will look into screw-on hinges.
JAPLO schrieb:
It is also important to pay attention to the correct size of the strips for the frame, so that the hinges close flush later and nothing gets stuck.I will definitely check that carefully to ensure everything works well in the end.
It is certainly a balancing act between stability and proper hinge function. Thanks to everyone for the valuable, very practical suggestions! If anyone has tips on selecting fabric types or care advice, feel free to share.
