ᐅ How can I update the look of Billy shelves to make them more modern?
Created on: 17 Dec 2024 08:37
Tanfetih
Hello everyone, I am planning to update my Billy shelves to give them a more modern look without completely replacing them. I am especially interested in simple and effective ways to modernize the shelves—whether through color schemes, mixing materials, lighting, or smart accessories. Do you have any specific tips or DIY experience on how to break up the typical Billy shelf design and give it a fresh, contemporary appearance? It is particularly important to me that the makeover remains cost-efficient and doesn’t require complex craftsmanship. Thanks in advance for your expertise!
Jensson
18 Dec 2024 13:42
Summary and brief guide for a quick renovation:
1. Cleaning and preparation: Remove everything from the shelves and thoroughly clean the surface.
2. Applying backing panels: Use self-adhesive foil or Formica sheets cut to size for the back panel. These can be removed cleanly and protect the wood.
3. Installing lighting: LED strips with adhesive backing work very well; choose dimmable versions for a better atmosphere.
4. Shelf design: Optionally use liners or protective films for covering.
5. Accessories: Select colored boxes, baskets, or books according to a color scheme to create more structure.
Common mistakes include applying paint directly onto untreated surfaces without primer or careless placement of backing elements. Also, colors that are too bright can quickly appear distracting.
Palenar
19 Dec 2024 10:54
Tanfetih schrieb:
I lean more towards a quick modernization that is also suitable for renters and does not cause permanent changes.
Understood, that really narrows down the options. In that case, I would also recommend using temporary wall hooks if you want to hang items like small plant holders or minimalist hooks for decorations. This adds a bit of flair without permanent drilling. Felt furniture pads can also be useful; choose colors that match your decor and attach them to the edges of shelves – a small but effective visual upgrade. As mentioned before, LED strips that are easy to install and remove work well to create a modern effect. Do you already have a color tone or style in mind? That way, it’s easier to narrow down the choice of films, boxes, and lighting.
