ᐅ How can I update the look of Billy shelves to make them more modern?
Created on: 17 Dec 2024 08:37
Tanfetih
Tanfetih
17 Dec 2024 08:37
Hello everyone, I am planning to update my Billy shelves to give them a more modern look without completely replacing them. I am especially interested in simple and effective ways to modernize the shelves—whether through color schemes, mixing materials, lighting, or smart accessories. Do you have any specific tips or DIY experience on how to break up the typical Billy shelf design and give it a fresh, contemporary appearance? It is particularly important to me that the makeover remains cost-efficient and doesn’t require complex craftsmanship. Thanks in advance for your expertise!
lisku
17 Dec 2024 09:04
The easiest way is to paint the shelves or cover the back panel with wallpaper. LED strip lighting can make a big difference, especially if it is warm white.
Palenar
17 Dec 2024 10:46
The topic of modernizing a Billy shelf is quite interesting and allows for various approaches. First, you need to consider the effect you want to achieve – minimalist, Scandinavian, industrial, or perhaps colorful. My recommendations start with the surface treatment: a often underestimated option is to sand the shelves completely and then paint them with a high-quality wood stain or chalk paint. Chalk paint has the advantage of being easy to apply and relatively affordable. It is important to choose the right primer to ensure good adhesion. Especially on the back panels, combining with films or self-adhesive wallpaper can create modern accents. However, care should be taken to avoid adhesive residue damaging the wood surface. Another aspect is the integration of light sources: LED strips are very easy to attach behind the shelves. I recommend using dimmable LEDs to allow flexible control of the lighting. When selecting accessories, I advise reduction – less is more, especially for a shelf intended to look modern. Open compartments combined with closed elements (such as small cabinets or boxes) create structure. If possible, you might also consider replacing the doors with frosted glass or applying some kind of film as a privacy screen. My question to you: Are you focusing more on a quick, minimally invasive redesign, or planning long-term changes with more effort?
Tanfetih
17 Dec 2024 11:02
Palenar schrieb:
My question to you: Is your focus more on a quick, minimally invasive renovation, or are you planning long-term changes that involve more effort?
Thank you for the detailed response! I am leaning more towards a quick modernization that is also suitable for tenants and does not cause permanent alterations. This means painting is possible as long as it can be removed without residue, but I want to avoid major remodeling or installing heavy doors.
KAULIS
17 Dec 2024 13:27
For a quick and residue-free renovation, removable liners (“Shelf Liners”) are ideal for the back panels. These come in a wide range of designs—from wood effects to metal looks. Additionally, using LED light strips powered by batteries or USB, which can be installed without drilling, is recommended. Important: choose matte colors, as glossy finishes often appear cheap. Alternatively, handleless stickers for the shelves offer a subtle way to enhance the appearance, for example, by highlighting the edges with color. Plain paint on the cabinet is often problematic in rental properties, so I find magnetic or adhesive solutions more practical.
koduga
18 Dec 2024 07:15
The ideas for lighting and films sound great. I know the feeling of wanting to change something but not wanting to put in a lot of effort or leave permanent marks. That’s why I believe small, reversible changes like colorful baskets or storage boxes in the compartments can also contribute a lot to the new look. It simply makes you feel more comfortable in your own home. Maybe the back panel could be covered with color only inside the individual compartments instead of the whole shelf? That would break up the classic look a bit.
