ᐅ How can I use IKEA PLATSA furniture in wet areas such as bathrooms?
Created on: 14 Apr 2024 09:38
jonken
jonken
14 Apr 2024 09:38
Hello everyone, I am currently considering how to use IKEA Platsa furniture effectively in the wet area of my bathroom. I am particularly interested in aspects such as moisture resistance, storage optimization, and the practical integration of sinks or taps. Are there any experiences regarding how durable and long-lasting Platsa components are when exposed to moisture, and what modifications are necessary to create a safe and functional bathroom solution? Additionally, it would be helpful to know which combinations of the Platsa systems are especially suitable for small to medium-sized bathrooms. Thanks in advance for your tips and suggestions!
klo61
14 Apr 2024 10:05
Hello jonken, your concern is very relevant because using furniture in wet rooms requires a good understanding of material properties and space planning. PLATSA is basically designed for living areas, but with some adjustments, it can also be used in bathrooms. The important points are:
- Protect surfaces from moisture (e.g., by painting, sealing, or applying foil)
- Ensure ventilation of the furniture to prevent mold growth
- Use mats or feet if the floor can get wet
Regarding the integration of washbasins, PLATSA cabinets are more suitable as storage space next to or below countertop basins, as they are not specifically designed for plumbing connections.
For small bathrooms, I recommend modular units with open compartments for towels and closed cabinets for cleaning supplies, so you can make the best use of the space.
If you need more specific suggestions, I am happy to share examples of conversions that I know.
nojaus
14 Apr 2024 11:21
klo61 schrieb:
PLATSA is basically designed for living spaces but can also be used in bathrooms with some modifications.
That sounds doable at first, although of course it carries some risks. I really appreciate it when people are willing to use furniture flexibly. Personally, some time ago I found that PLATSA gave a small bathroom a lot more character and functionality.
However, the concern about moisture remains, and it held me back for a long time. So I treated all the surfaces with clear varnish and added water-resistant foil to the back panels. That makes me feel more confident.
Does anyone have further experience, especially regarding how these pieces hold up to moisture over time?
Fitigu
14 Apr 2024 13:48
jonken schrieb:
how durable and long-lasting PLATSA units are when exposed to moisture and what adjustments need to be made
From a cautious perspective: IKEA PLATSA uses particleboard-based modules that will definitely swell or get damaged when exposed to high humidity and water droplets. Without proper sealing, they are not classified as moisture-resistant furniture.
Technically advisable measures include:
- Applying waterproof paint or specialized marine varnish to all visible surfaces
- Sealing edges, as water tends to penetrate there most easily
- Promoting active ventilation (windows, exhaust fans) and avoiding flush mounting the furniture directly against the wall
- Creating a gap from the floor using feet or baseboards
- For installing sinks, original PLATSA units are only partially suitable; it is recommended to retrofit with additional moisture-resistant panels or use the IKEA sink base cabinet options.
In short: PLATSA is better suited for dry or well-ventilated bathroom areas, not directly in places exposed to water splashes.
sanjon
14 Apr 2024 15:02
PLATSA can be used in the bathroom if everything is properly sealed and no direct water contact surfaces are created.
For washbasins, it is better to use furniture designed specifically for damp rooms.
Open shelves work well for towels.
peovin
15 Apr 2024 08:17
I have PLATSA installed in my guest bathroom as storage under a vessel sink. It was important for me to have a waterproof base and sufficient clearance from the floor. Otherwise, I have had good experiences, especially because of the flexible sizes and configurations.
