ᐅ How can I use IKEA PLATSA effectively in combination with PAX?
Created on: 21 Oct 2021 17:03
yvorsu
yvorsu
21 Oct 2021 17:03
I am currently planning to reorganize my storage space and want to specifically combine the Ikea furniture series Platsa and Pax. My question is: How can I effectively use Ikea PLATSA together with PAX to achieve both flexible use of space and an aesthetically pleasing, functional solution? Specifically, I am interested in how to best coordinate the different module sizes and fronts, whether combinations are particularly suitable for a bedroom or hallway, and what tips there are for mounting and interior fittings to ensure the setup is stable and durable.
I would really appreciate practical experience, planning advice, or even critical comments, as I have only used the furniture separately so far and the systems are quite different. Thank you in advance!
nanidra
21 Oct 2021 19:37
yvorsu schrieb:
How can I effectively combine Ikea PLATSA and PAX to achieve both flexible use of space and an aesthetically pleasing, functional solution? Specifically, I’m interested in how to best coordinate the different module sizes and fronts, whether certain combinations are particularly suitable for a bedroom or hallway, and any tips for mounting and interior fittings to ensure the whole setup is stable and durable.
Interesting approach! But honestly: mixing PLATSA and PAX is not as straightforward as most people think. The modules differ not only structurally but also in concept. PAX focuses on classic wardrobe units with doors and drawers, while PLATSA is designed mainly for flexibility and adaptability, offering both open and closed elements.
In my opinion, if you insist too much on visual uniformity, you’ll often be frustrated because the fronts rarely match perfectly, even though Ikea seems to offer similar color tones. However, this allows you to deliberately create contrasts and a kind of “intentional disorder” that can look really cool—if that’s what you’re aiming for.
For the bedroom, I’d choose PAX as the main wardrobe because stability and interior fittings are more important for clothes, using PLATSA as a supplement for storage of items that are not needed every day. In the hallway, PLATSA lets you customize more, for example with open shelves for shoes or bags, while PAX might be oversized there.
Regarding mounting: make sure to pay close attention to the wall fixings for both systems and try not to overload them. PLATSA especially needs the load to be distributed across the entire surface.
My tip: avoid stacking PLATSA units on PAX or vice versa, as their heights don’t always align well—better place them side by side. This gives you more flexibility and makes rearranging easier if needed.
PLOMA
22 Oct 2021 08:49
nanidra schrieb:
The modules differ not only structurally but also in their design concept. PAX focuses on classic wardrobe units with doors and drawers, while PLATSA primarily offers flexibility and adaptability through a combination of open and closed elements.
I fully agree with your point, nanidra. I would like to add some more technical details here to best support the questioner during planning:
- Dimensional variations: PAX and PLATSA differ significantly in their widths, depths, and heights (for example, PAX commonly comes in widths of 50/75/100 cm (20/30/40 inches), while PLATSA tends to have smaller dimensions like 30/60/90 cm (12/24/36 inches)). It is important to carefully check how they will be placed next to each other and whether to keep heights consistent or use visual transitions (e.g., filler panels) to compensate.
- Interior fittings: PAX offers a wide variety of shelves, clothes rails, drawers, and accessories, whereas PLATSA is more modular and straightforward, often consisting of open spaces or simple drawers. For practical use, it works best to consider PAX as the “base unit” for clothing and PLATSA for complementary storage, such as boxes, books, or occasional garments.
- Stability: Both systems always need to be fixed to the wall. When combining them, do not underestimate the spacing. Especially with taller wardrobes, securing seals or braces are important to keep the construction torsion-resistant.
- Fronts: For visual consistency, you may find similar colors like white or gray on fronts for both PAX and PLATSA, but the surface textures differ slightly. I recommend checking physical samples onsite.
One more question for you: Are you planning to combine PLATSA and PAX in one room as an integrated piece of furniture, or will they be separate units placed next to each other? This will significantly affect the planning!
Takutau
23 Oct 2021 11:21
PLOMA schrieb:
One more question for you: Are you planning to join PLATSA and PAX in one room as a combined unit, or rather as several separate pieces placed next to each other?
In my opinion, that is the key point. Especially for someone combining both furniture systems for the first time, it’s important to clarify this in advance. I’d like to give you a few tips on how to approach this from a practical perspective:
- If you actually want to connect the furniture, for example with shared top panels or side covers, you definitely need precise measurements and tools to compensate for small misalignments. Many people underestimate the amount of work required to achieve a perfect fit.
- If placing them separately next to each other, it’s much easier to mix different styles or colors to your advantage. This creates a more modern look—a kind of “accent furniture.”
- The interior fittings are very flexible in both systems, but PAX is more designed for traditional wardrobes, while PLATSA is more multifunctional—such as for children’s rooms, hallways, or as a living room cabinet.
- For mounting: Always use the included fasteners and secure the cabinets to the wall. This is especially important with combined units to ensure safety, as the weight is distributed over multiple points.
Finally, I recommend carefully sketching the height, width, and depth of the planned combination before placing your order, either in-store or online. It’s also worth using the IKEA planning tools in detail and transferring the dimensions of individual parts onto paper. This way, you can avoid surprises on assembly day.
I hope this helps you a bit!
boelnu
24 Oct 2021 09:08
yvorsu schrieb:
How can I effectively use Ikea PLATSA combined with PAX to achieve both flexible room usage and an aesthetically pleasing, functional solution?
Your question really resonates with me because I tried exactly the same thing about a year ago. At first, I was completely overwhelmed by the different options and the modularity.
One thing I learned is that you should always keep the primary function of the furniture in focus. For me, that means: PAX is my wardrobe for clothes and laundry—I want the perfect interior layout with pull-out drawers and hanging rods. That works really well, even though the fronts aren’t 100% identical to PLATSA.
I use PLATSA as a complementary storage solution for items I use less often, like bed linens, games, or decorations. Thanks to the relatively shallow boxes, you can easily accommodate items of different sizes.
In my setup, I positioned PLATSA as a side extension cabinet, but not directly attached to PAX. That way, I keep flexibility and can move or adjust the modules separately later on.
Something else that might encourage you: Assembly is quite quick with PLATSA thanks to the snap and screw system. The wall mounting of the heavy PAX was a bit tricky, but it’s manageable with the right anchors and screws.
One last note: When it comes to design, it helps to deliberately use different fronts as a design element rather than trying to make everything uniform. This makes the overall look more lively and personalized.
