ᐅ How can I use Ikea Pax wardrobes for TVs and electronic equipment?
Created on: 2 Nov 2024 09:43
Nufomu
Nufomu
2 Nov 2024 09:43
I am planning to use an Ikea Pax closet system as a central solution for my TV and related equipment. I have the question: How can I best use Ikea Pax for a TV and electronics so that everything is well stored, properly ventilated, and looks appealing?
I understand that Pax is primarily designed as a wardrobe and not specifically for electronics. However, I want to take advantage of the flexibility of the modular interior fittings. I am particularly interested in:
- Which interior fittings (shelves, drawers, inserts) work best for devices like receivers, gaming consoles, set-top boxes, sound systems, and cable management?
- How do you handle ventilation inside the closed Pax units to prevent overheating of devices?
- Are there any practical tips for installation and wiring inside the cabinet?
- How do you deal with the visibility of the screen and remote control signals?
I look forward to your experiences, recommendations, and creative solutions. Thank you in advance!
Davidleo
2 Nov 2024 10:29
Wow, great question! 😊 I love it when people find creative ways to use Ikea Pax!
I personally built my TV into a Pax wardrobe – it feels very elegant because you can nicely hide everything. It’s important to include open shelves or cut out the back panel where heat needs to escape. I also mounted the TV on a specially adapted board that is sturdy enough to support the weight.
Nufomu schrieb:
How do you handle ventilation in a closed Pax for devices that get warm?
Ventilation gave me the most trouble! I cut ventilation slots in the doors at the top and bottom and covered them with fan grilles. This greatly improves air circulation.
Cable management is also very important – I used cable channels and hid everything behind a cable flap. It looks great and prevents any mess.
Go for it, because with a bit of courage you can fully customize your Pax. I’m happy to help if you need tips! 😄
Dilen
2 Nov 2024 12:54
Hello Nufomu,
Your question is very precisely formulated, which I really appreciate, as using Ikea Pax as media furniture indeed requires careful planning and technical understanding.
First, regarding the interior fittings: I recommend definitely using open shelves from the Pax series, because closed drawers or cabinet elements significantly restrict air circulation. Plexiglass inserts can be used if you still want some visual separation while allowing heat to escape.
There are different approaches to ventilation:
- Leaving out the back panel or parts of it to create air openings
- Installing small, quiet fans for active ventilation, exhausting air to the outside
- Milling ventilation slots into the side panels or doors (be careful regarding stability)
For cable management, make sure to use cable ties or hook-and-loop straps and label the cables whenever possible. Power adapters and chargers generate heat and should not be stacked on top of each other.
For remote control signals, either glass or acrylic doors with infrared transparency are suitable, or a simple infrared repeater that transmits the signal from outside into the cabinet.
One more question: How large is your TV and do you plan to keep the cabinet completely closed or at least partially open? This greatly affects the approach.
Best regards!
klo61
2 Nov 2024 13:37
Hello Nufomu,
I would like to share some basic tips that are always helpful when using Ikea Pax as a media cabinet.
- If possible, use glass sliding doors or complete the cabinet with glass doors. This way, you can place the TV inside without losing picture quality.
- For ventilation: Round cutouts at the top and bottom of the back panel are very helpful. Make sure they are well positioned to allow warm air to escape.
- Use power strips with surge protection to keep your equipment safer.
- For mounting the TV, a wall mount attached to the cabinet’s back panel works well – some users drill through the back panel for this, but be careful to maintain structural stability.
If you have specific questions about devices or mounting tips, feel free to ask. There are many small details worth considering.
Kinbu
3 Nov 2024 08:15
I would like to add that adjusting the Pax system for TV and technology also depends on your personal usage habits.
- For cable management, you can attach special cable channels or cable trays, which help keep things organized.
- If you are using the latest technology, make sure to leave enough space behind the TV (at least 10-15 cm [4-6 inches]) to allow heat to dissipate properly.
- There are also inserts with ventilation holes specifically designed for devices, which I have had good experiences with.
- A remote control works reliably through glass, so if you have doors, avoid opaque doors in front of the TV.
The most important thing is to measure the cabinet carefully beforehand, especially considering the depth of your devices, so that nothing is cramped and air circulation is ensured.
Good luck with your project!
