ᐅ How can I use Ikea Pax wardrobes for storing collectibles?
Created on: 5 Jan 2024 09:12
Sisijo
Sisijo
5 Jan 2024 09:12
Hello everyone, I am considering using my Ikea Pax wardrobe as a storage system for my growing collection of figures, models, and smaller collectibles. I want to focus mainly on protection against dust, clear organization, and visual presentation. Do you have any tips or experiences on how to best modify or complement the Pax to make the storage of my collection safe, accessible, and visually appealing? I am also concerned about long-term protection, so avoiding constant sunlight exposure or high humidity for the items. Are there any special compartments, lighting options, or other accessories you would recommend?
V
vin_leo
5 Jan 2024 09:45
Hey Sisijo! It’s great that you want to use the Pax system for your collection – it’s really versatile! 😊 I’d recommend installing acrylic glass doors or panels to keep everything dust-free while still being able to see it all. Inside, you can use drawers and boxes, which are usually available as accessories. For that wow factor, add LED strips at the top or sides, preferably dimmable. This creates a nice atmosphere without the risk of overheating. Oh, and check if you can line the back panel of the cabinet with a good fabric or thin foam rubber – this protects delicate parts from vibrations. Have fun with your project!
Jeanbar
5 Jan 2024 10:33
Hello Sisijo, the Pax wardrobe is generally a reliable storage furniture option thanks to its modular design. Make sure to know the internal dimensions exactly so you can purchase suitable boxes or divider systems. A clear recommendation is to store heavy collectibles at the bottom to ensure stability. For delicate items, foam inserts that can be cut to size are also useful. If your collection includes different types of objects, you can customize the compartments accordingly: small drawers for tiny parts, solid shelves for larger figures. Ventilation options should not be overlooked either, as moisture can be harmful to many collectibles.
CHENFAR
5 Jan 2024 11:56
Using Ikea Pax for storing collectibles is quite practical due to its modular interior design. Here are some structured recommendations:
- Use glass doors or acrylic fronts to protect against dust while keeping your items visible.
- Install LED lighting with minimal heat output (e.g., LED strips) to highlight the display visually.
- Use shelves made of sturdy materials (wood or metal) to accommodate objects of varying heights.
- Add adjustable dividers and foam inserts for delicate items.
- Ensure secure anchoring to the wall to reduce the risk of tipping.
- Provide sufficient air circulation if necessary to prevent moisture damage.
This will give you a versatile, protective storage system with good visibility.
V
vin_leo
5 Jan 2024 12:07
Sisijo schrieb:
I am also concerned about long-term protection, so no constant exposure to sunlight or high humidity for the items.
Very good points! Sunlight and moisture are well-known enemies of collectibles. If you use the Pax system in a room with windows, it’s best to apply UV-protection film or keep it out of direct sunlight. To manage humidity, a small electric dehumidifier placed near the cabinet often helps, especially for models made of plastic or other sensitive materials. Otherwise, the collection will suffer, no matter how well you store it.
KNUTGI
5 Jan 2024 13:28
Additional note on interior customization: The Pax carcass systems work well with adjustable shelf fittings. If you need some space between your figures or different heights, feel free to swap the shelves for higher or lower ones. Also, small turntables for figures look great—they allow you to simply rotate them to see everything, almost like a mini showcase. 😎 Presenting your collection this way makes opening the cabinet much more enjoyable.
