Bofolkma4313 Oct 2024 09:23Hello everyone, I have a specific question: How can I use IKEA Hemnes furniture outdoors without it quickly getting damaged or looking worn? I am thinking of placing some pieces on the terrace, such as dressers or small cabinets, because I would like to create some storage space there. However, I know that Hemnes furniture is mainly designed for indoor use and is made of partly solid pine wood. Therefore, I am interested in what preparations, treatments, or protective measures make sense to keep the furniture durable outdoors—whether through stain, varnish, or other methods. Also, I would like to know if anyone has experience with using Hemnes furniture in vertical or covered outdoor areas where the furniture is not continuously exposed to direct weather. It would be great if you could share some tips!
Hello Bofolkma43, I think your question is very well formulated and practical. IKEA HEMNES furniture is primarily designed for indoor use, so caution is advised if you want to use it outdoors. In general, you should avoid exposing the furniture directly to rain, snow, or high humidity, as pine wood can swell and warp.
- As a first step, applying a good wood stain or wood preservative that is water-repellent yet breathable is recommended. Make sure the product is specifically suitable for exterior wood.
- Before application, the furniture should be lightly sanded to roughen the surface, then apply the stain in several thin layers.
- A covered area or a sheltered patio is ideal to reduce direct exposure to weather conditions.
- Additional protection would be to cover the furniture with waterproof tarps when not in use for extended periods.
Regarding stability, slight deformations can occur depending on the climate. If you want to place the furniture directly on the ground, I recommend placing it on small wooden blocks to prevent prolonged contact with wet soil.
In this case, it is especially worth treating the back panels and bottom boards carefully, as these parts are most prone to absorbing moisture.
I hope these tips help you out!
Bofolkma43 schrieb:
Meine Überlegung ist, einige Stücke auf der Terrasse zu verwenden, zum Beispiel Kommoden oder kleine Schränke
Hello everyone, I would like to add a few important points to GiRoyce’s comments that are often overlooked.
HEMNES is sturdy, but the solid wood structure poses challenges, especially for outdoor use, such as:
- Exposure to UV light, which causes the wood to fade or become brittle over time.
- Fluctuating humidity levels, leading to stress and cracking.
In your case, Bofolkma43, it is practically essential to treat the furniture with a high-quality UV protection. There are special wood oils or varnishes designed for this purpose.
My advice: If you paint the furniture, use a coating specifically made for pine wood that remains breathable. Completely airtight finishes quickly cause internal moisture buildup, which can damage the wood.
In addition to protecting the furniture, I also recommend regularly checking and adjusting all movable parts (drawers, doors), as the wood can expand or contract with changing humidity.
Regarding placement:
- A covered or wind-protected area works wonders.
- If you want to leave the furniture outside permanently, it’s also worthwhile to attach a protective foil to the inside of the back panel to prevent moisture from behind.
In summary, I can say: With proper care and protective measures, HEMNES furniture can certainly be used on a well-protected terrace, but the effort and regular maintenance should not be underestimated.
Hello Bofolkma43, I have read your thread carefully and would like to offer you a structured approach on how to use HEMNES furniture outdoors – I will also address potential sources of problems.
1. Check condition: Buy furniture pieces without visible damage if possible, and make sure the wood is completely dry.
2. Prepare the surface: Sand the furniture thoroughly (grit 120-180) so that the stain/varnish adheres better.
3. Apply protection: Use a high-quality, breathable wood stain or a varnish with UV protection and water repellency.
4. Apply multiple coats: Apply at least two to three coats, sanding lightly between layers.
5. Location: Choose a covered, wind-protected place, preferably with a concrete or tile floor. Use wooden blocks or rubber pads to prevent water from wicking up from below.
6. Regular maintenance: Check annually for peeling spots, damage, or cracks and treat them immediately.
Common mistakes:
- Placing furniture directly on the ground – promotes rot.
- Using pure varnish that traps moisture in the wood – leads to cracking.
- No maintenance during the year – protection deteriorates.
Following this method will keep the furniture looking good and stable for longer. If you like, I can also share tips on a special stain that I have had good experiences with.
Common mistakes:
