ᐅ How can I use IKEA BESTA for storage under the stairs?
Created on: 28 Jul 2015 08:43
ivanon
ivanon
28 Jul 2015 08:43
Hello everyone, I have a specific question about using Ikea Besta as storage under the stairs. My stair area has a rather irregular shape, which makes integrating storage furniture a bit more challenging. I would like to know what options are available to use the BESTA system in a functional and as customized a way as possible in that space. It is also important for me to understand the best approach to planning in order to make optimal use of the unused area, which modules are suitable, and whether modifications to the furniture or additional elements (such as shelves, doors, etc.) are advisable. Additionally, I am interested in how the whole setup performs in everyday use, for example if you have any experience with sliding cabinets or versatile door options. Thanks in advance for your tips!
bapeo39
28 Jul 2015 09:12
ivanon schrieb:
I would like to know what options are available to use the BESTA system functionally and as custom-fit as possible there.
The best approach is to choose different BESTA modules in various heights and widths, which you can then place side by side to fit your space. The cabinet depths should be kept as shallow as possible so it doesn't look bulky under the stairs. Using doors or sliding doors makes the area appear slimmer and more accessible.
dopite
28 Jul 2015 14:05
bapeo39 schrieb:
The best option is to choose different BESTA units in various heights and widths, which you can then place side by side according to your measurements.
I can only agree and would like to add a bit more detail:
1. First, carefully measure the height and depth under your staircase. Often, the height above the steps varies, which makes modular solutions the most suitable.
2. IKEA BESTA offers different depths, for example, 20 cm (8 inches) and 40 cm (16 inches); use shallower units for the narrower areas.
3. Combine open shelves and closed cabinets to create flexible storage and accommodate various items.
4. Using sliding doors instead of traditional hinged doors allows for efficient use of space, as the doors don’t need a swing radius. This is especially practical under stairs with limited clearance.
5. DIY modifications to the units, such as trimming the back panels or adding caps to angled sides, can be a bit time-consuming but are worthwhile for a perfect fit.
I would also recommend making a rough cardboard cutout before purchasing, to get a feel for the right combination.
temeli
29 Jul 2015 11:37
ivanon schrieb:
I’m also interested in how the whole setup performs in everyday use, for example if you have experience with sliding cupboards or versatile doors.
Oh yes, BESTA under the stairs works great! I had a similar space and used sliding doors – it saves a lot of room and looks really stylish! 😍 If you have limited space, definitely go for sliding doors, as the comfort is much less compromised.
Also, I would leave a few open compartments for quickly stashing things, so you don’t have to open doors all the time. And it’s fun if you get creative and design it yourself! 🙂 So go for it!
elgla
30 Jul 2015 19:46
temeli schrieb:
I had a similar amount of space and used sliding doors – it saves a lot of room and looks really stylish!
I understand the enthusiasm, although I also faced some challenges in my implementation. Especially adapting to the sloped ceiling and uneven walls was difficult. A tip from me: use flexible cabinet systems for the side walls. I added BESTA modules with white MDF panels on the open side and used custom-made doors to avoid a bulky look.
I can also confirm that combining open shelves and closed doors creates a good balance between storage space and visibility. Don’t get discouraged if the space is very unusual – with some patience, it works out!
