Hello everyone, I am considering using the Ikea Besta as a base for a work surface in my hobby room. My goal is to create a robust and flexible surface that can serve as both a crafting table and for smaller DIY projects. I am unsure about the best approach: which overlay or reinforcement is suitable to make the surface stable and durable? And how can I attach additional elements or holders to the BESTA system without compromising its stability? It would also be very helpful to get recommendations regarding the working height and surface treatment to ensure the setup remains long-lasting and comfortable. I look forward to tips, experiences, or examples of how you use BESTA as a work surface in your hobby room!
To stabilize the work surface of the BESTA, I recommend placing an MDF board of the appropriate size on top and securing it to the frame with screws. For the surface, you can simply choose a durable laminate board, which is easy to maintain and sturdy. Just make sure the height is ergonomically suitable for you, and if necessary, add legs underneath.
Your question is very well posed, and I’m happy to explore it in more detail because the topic is quite versatile. First, you should consider exactly what kind of work you want to do on the surface: fine crafts, model building, or also sawing and gluing? This greatly influences which materials you should choose. Basically, the BESTA system is sturdy by design, but the standard top layer is more of a decorative panel that tends to scratch and doesn’t always withstand pressure well. Therefore, I would recommend the following approach:
- Use a sturdy 19 mm MDF board as a base, as it is easy to work with and has low deformation.
- For the surface, you can use a durable worktop made of wood or plastic, for example, plywood with an HPL (high-pressure laminate) coating. This protects against damage if you work with paints or adhesives.
- You can securely attach the MDF board underneath the BESTA with cordless drills by pre-drilling through the side panels and countersinking screws. Be careful not to drill too close to the edges.
- For additional elements such as clamps or holders, it is advisable to recess suitable cutouts or mounting plates in the MDF or worktop in advance to better distribute loads.
- Regarding working height: the BESTA is about 38–40 cm (15–16 inches) tall, which is rather low for standing tasks. To work ergonomically, you can either fit higher table legs or place the cabinets on sturdy platforms. If you mainly sit, you should adjust the seating height accordingly.
I would be interested to know which tools and materials you plan to use most, so I can provide more specific recommendations.
Here is a brief tutorial on how to set up the Ikea BESTA as a stable and functional work surface for your hobby room:
1. Planning the dimensions: Measure how much space you need and how many BESTA units you want to combine. Also consider the optimal working height (about 90 cm (35 inches) for standing work).
2. Choosing the worktop: A 19-22 mm (¾ inch to ⅞ inch) plywood panel with an easy-care surface (e.g., HPL or oiled wood) is ideal. This type of panel is easy to drill, sand, and resistant to impacts.
3. Fixing steps:
- Place the worktop on the BESTA cabinets.
- Use brackets or adapters underneath the top (e.g., metal brackets attached to the cabinet) to prevent the top from shifting.
- Screw the worktop through the side panels of the BESTA into the base frame, pre-drilling the holes to avoid splitting the material.
4. Reinforcement:
- If needed, add cross braces under the worktop, for example made of wooden slats, to increase stability.
- Make sure the overall standing stability is maintained, especially if you use heavy tools.
5. Additional elements:
- For better organization, you can attach hooks or magnetic strips to the side panels.
- Power strips can be conveniently mounted on the back.
6. Protecting the surface:
- Seal wooden surfaces with varnish or oil to prevent moisture and stains.
The system is quite flexible and can be adapted later. Have you also considered lighting above the workspace? Good lighting makes work much easier.
3. Fixing steps:
4. Reinforcement:
leebi7 schrieb:
I’m interested in knowing which tools and materials you plan to use most, so I can give more specific recommendations.Good question! I mainly want to use the table for model building, occasional woodworking (e.g., sawing, sanding), and some electronics soldering. The surface should be sturdy but not too heavy, as I want to be able to move it if needed. I plan to attach tools like vises or small clamps, but I’m unsure how best to integrate these into the surface without compromising stability. An adjustable height would be nice, but I’ll mostly be sitting while working. Thanks for all your detailed contributions so far!
Hello, I’ve been following your posts and would like to address your specific requirements: For model building and electronics, a smooth, clean surface is important, which can also handle minor contamination without issues. Therefore, instead of a coarse-pored MDF board as a work surface, I would recommend using a plywood board with a smooth surface and treating it with a clear, matte finish – this is durable, easy to clean, and improves longevity.
To attach vises or other clamps, you can install special inset plates that you mill into the board in advance. This way, you distribute the stress better instead of screwing directly into the worktop, which could cause material to tear out over time.
Since you will mostly be sitting, a working height of about 70–75 cm (28–30 inches) is optimal. If the BESTA carcasses don’t reach this height, you can either shorten the legs or add a height-adjustable table frame. There are also affordable table lift systems available that allow you to adjust the height flexibly.
If you want to be able to move the surface, also consider smooth-running but lockable casters under the base – this maintains stability while making the furniture mobile.
If you like, I can send you more precise dimensions and product recommendations.
