I bought a Klamby sleeper sofa during the special Tuesday sale in December. Since I recently moved, I am only now getting around to using it for guests.
You might laugh at me, but I can’t figure out how to convert the sofa into a bed. We have pulled on the seating area from different sides, front and back, thinking it needs to fold out and be placed in front of the sofa.
Or is there some other trick to it?
Help!!!!
Thanks in advance for your support.
Regards,
sk1
Help!!!!
Regards,
sk1
Hi sk1,
if it's the same sofa as the one I have, you just need to fold up the seat part until it clicks, and then pull everything back down - with a bit of force. This will give you a small reclining area. Then you just have to pull out the lower part, which is the slatted frame, and lay the rest of the sofa over it. And voilà! Your sofa is now a bed!!! 😉
Hope I could help!
Best regards, Expedit
Hope I could help!
Hello Expedit,
thank you for your reply.
Unfortunately, it seems we do not have the same sofa.
I believe the Klamby sofa offered does not have a slatted frame like your sofa, but rather you have to somehow pull out and unfold the foam seat surface. However, since it is sewn together at the back and the backrest extends quite far, this makes it difficult...
Which sofa do you have?
Regards
sk1
Regards
sk1
