ᐅ How can I transform IKEA Besta units into an elegant room divider?
Created on: 14 Nov 2015 09:17
hedda
I am considering using my IKEA Besta shelving system as an elegant room divider in my apartment. I am especially interested in how to arrange or upgrade the modules so that they are visually appealing while also functioning effectively as a room divider. I don’t want a simple partition, but something that enhances the space, for example with backlighting, a mix of open and closed compartments, or maybe with special finishes or decorative elements.
Do you have any ideas or experience on how to modify Besta to achieve a modern, elegant look that really works as a room divider? Perhaps also tips on stability and installation to ensure it stands securely?
Thank you in advance!
hedda
15 Nov 2015 14:02
leebi7 schrieb:
- Optional: A thin, transparent safety glass back panel not only increases stability but also adds depth and reflections that enhance the design.
That sounds very interesting! Do you have any recommendations on where to get glass cut to the right dimensions and how to best secure it? I have little experience with glass, but the material sounds very elegant and modern.
Regarding the colors: My apartment is mostly decorated in light tones, lots of white and light wood finishes. That’s why I’m leaning towards white or light gray fronts, possibly with a matte finish, since I often find high gloss a bit too cold.
Thanks in advance for the tips on stabilization—that’s exactly what I was looking for!
JAPLO
16 Nov 2015 09:42
hedda schrieb:
Do you have recommendations for where to get glass in the right sizes and how to best secure it?
Safety glass is usually available from building supply or glass specialist retailers. Look for toughened glass (tempered glass), which breaks into small, less dangerous pieces under stress. For mounting, you can either use special glass brackets that are easy to screw in, or glass clamp holders that can be attached to the back panel. It’s important to fix the back panel as flush and securely as possible to ensure it truly supports stability.
Alternatively, an acrylic glass sheet is easier to handle but is less scratch-resistant and often looks less high-end.
If you have any questions about the exact procedure, I’m happy to help.
dopite
16 Nov 2015 11:29
hedda schrieb:
I have seen that LED strips can be integrated well, but what is the most elegant way to do this without the cable mess being visible?
For cable installation, I recommend the following:
- Plan from the beginning where the LEDs will be placed and how the electrical circuit should run.
- Route the cables along the inside of the back wall and secure them with thin cable clips, which are also available as self-adhesive.
- If possible, use so-called low-voltage LED strips connected with slim connectors, which reduces cable clutter.
- Avoid visible extensions or loose cables, especially at module edges, as this disrupts the design.
- It is advantageous to use LED strips that can be dimmed and have adjustable color temperature via remote control or app, allowing you to perfectly adapt the lighting to the room.
If you like, I can also provide you with a sample materials list and a short step-by-step guide.
