ᐅ How can I tell if the screws in IKEA PLATSA are properly secured?
Created on: 4 May 2023 08:34
ariftra
ariftra
4 May 2023 08:34
I recently assembled an IKEA Platsa shelving unit and now I have the question of how to accurately determine if the screws are properly tightened. This system often uses connectors and screws where it is not always immediately clear if they are fully tightened or if they need to be tightened further. Is there a proven method to ensure that all screws are secured well enough for the unit to stand stable and not be at risk of damage from loose connections?
So far, I have mostly tightened the screws with a regular screwdriver, but I am wondering, for example, if any wobbling or slight movement of parts is always a sign of insufficient fastening, or if this might be normal for Platsa.
Perhaps some of you have experience with this furniture and can offer tips on how to recognize the correct screw or connection torque, or how to check for possible errors during assembly? Thanks in advance for your help!
LOGEMIN
4 May 2023 09:12
Good morning!
Your question about how to tell if the screws in IKEA PLATSA are properly secured is very important for the stability of the shelving unit. Here is a brief guide to help you assemble it correctly:
- First: PLATSA often uses cam lock fittings or dowels plus screws. It is important that the screws are tightened firmly, not just by hand, so that no gaps remain between the components.
- After tightening, gently tap the furniture: If any parts move noticeably or rattle, it usually means a screw is not fully engaged in the thread or the cam lock is not completely turned.
- A good visual indicator is the appearance of the joint: There should be no visible gaps, and all edges should be flush and aligned.
- For checking: Use a good screwdriver or a cordless drill with torque control, so you don’t overtighten the screws—otherwise, the material could break.
- If the entire structure wobbles, this is almost always a sign of loose screws. For PLATSA, a screw may be misplaced if a cam lock locking mechanism is not properly seated.
In short: there should be no gaps, no noticeable wobbling of individual components, and a neat, tight fit visually. Take your time and systematically check each screw connection—it’s worth the effort.
If you’re uncertain, a second person holding the unit can help, as you can easily feel if something is turning.
Hope this helps!
V
vinpau
4 May 2023 10:05
Hey ariftra, I agree with LOGEMIN’s explanation and would like to add the following:
A small tip from me – especially with PLATSA, it’s really worth taking your time and initially tightening each screw lightly, then gradually tightening them fully. This helps prevent stress on the material and ensures everything ends up secure and stable!
I still remember assembling my PLATSA and checking at each step that all parts were really tight – and that definitely paid off!
If you ever feel that a screw turns too easily, it’s better to tighten it a bit more, but don’t over-tighten!
Definitely don’t rush the process; every turn of the screwdriver counts, and with some patience, the shelf will feel really solid afterward. Good luck!
Kukar
4 May 2023 12:47
Brief and to the point:
- Screws must be tight, but not overtightened.
- No visible gaps.
- Components must not wobble.
- The cam lock must be fully engaged.
If all this is correct, everything will fit properly.
sifope
5 May 2023 08:16
LOGEMIN schrieb:
After tightening, you should gently “tap” the furniture: if individual parts move noticeably or rattle, it usually means a screw isn’t fully engaged in the thread or the cam lock isn’t completely turned.
That’s a good tip, but I would be cautious about claiming that slight movement of components always indicates errors or loose screws.
You need to differentiate: PLATSA often consists of particleboard and connecting materials that allow for minimal flexibility. Some slight give is therefore partly inherent in the design and is not necessarily a clear sign of insufficient stability.
I recommend simulating load by placing weight on shelves and then checking if stronger movements or creaking occur.
Also: How exactly do we define “fits well”? For me, an assessment should also include long-term stability under real conditions, not just immediate firmness after assembly.
What do you think—how can long-term evaluation be mapped and monitored?
