ᐅ How can I tell if Malm replacement parts are compatible?
Created on: 4 Feb 2022 08:37
bauso
Hello everyone, I have a question that has been on my mind for a while: How can I tell if replacement parts for Malm furniture actually fit?
I am specifically referring to third-party or aftermarket parts sold as replacements for the Malm furniture system. They are often advertised as compatible, but how reliable is that really?
I have considered comparing the dimensions carefully, but sometimes the measurements aren’t provided in detail or the descriptions remain quite vague.
Are there any reliable guidelines to watch for – for example, specific tests, fit checks, or even practical experience from everyday use?
Or how do you handle it when the parts aren’t directly from the manufacturer? Thanks for your advice!
tyson51
5 Feb 2022 07:11
From my experience, the most important indicator of whether Malm replacement parts will fit is to know the original item number or the IKEA product number.
Tinaneo schrieb:
How much can you really trust third-party replacement parts, considering that IKEA itself makes even the smallest changes to dimensions or materials in new productions?
That is an important point. Even with original IKEA parts, there can be slight variations depending on the production period.
Therefore, I recommend specifically asking third-party suppliers for compatibility information based on exact model numbers and, if possible, referring to the pre-assembly process.
Additionally, you can often find tables in forums showing the year of manufacture and exact part numbers, which can make searching easier.
Tevin
5 Feb 2022 08:27
I would like to revisit the topic of material and tolerance, as it is often underestimated.
Tinaneo schrieb:
Don’t just look at the dimensions, but also check material quality and tolerances
Dimensions alone are not everything. A replacement part may fit mechanically perfectly, but if the material is too brittle or too soft, it can quickly be damaged during assembly or use.
In addition, surface and thread tolerances are crucial for a stable connection. With Malm, special attention should be paid to the smoothness of the screws and the fit of the dowels.
If possible, it is best to assemble the replacement part in a calm environment as a trial and test for a secure fit before fully installing it.
islaron
6 Feb 2022 17:45
For compatibility, it is often sufficient to check the drill hole spacing and connector types.
If these match, the parts are very likely compatible.
It should also be considered that Malm uses a modular system in some product lines, so not all parts are universally compatible.
Takutau
7 Feb 2022 09:53
Hello everyone, in case this topic is still relevant:
I would like to add that when purchasing Malm replacement parts outside of IKEA, you should also pay attention to the return policy. Since there are often uncertainties regarding dimensions or construction variants, a reliable return policy is invaluable.
KAUDRA62 schrieb:
If people often write that the part fits without any problems, then that is at least a good indication.
Reviews are therefore really important, as is clear communication with the seller to clarify any questions directly.
And last but not least: Sometimes it is worth contacting IKEA directly to ask for the correct part number before ordering.
