ᐅ How can I sustainably restore IKEA BRIMNES furniture?
Created on: 6 Jul 2024 14:23
Lulezar
Lulezar
6 Jul 2024 14:23
Hello everyone, I am looking for concrete and sustainable methods to restore IKEA Brimnes furniture. I am less interested in superficial repairs and more focused on an environmentally friendly and durable approach—measures that conserve materials, are health-conscious, and improve the furniture not only visually but also functionally. Does anyone have experience with the best way to remove or refinish the surfaces without using harsh chemicals? Are there sustainable alternatives to paints or varnishes that are compatible with the materials used in Brimnes? I have noticed that the carcass is usually made from particleboard with a foil finish, and I am wondering whether this layer should be preserved or replaced with another eco-friendly solution. I would also appreciate tips on sanding, cleaning, or reusing damaged parts. Thanks in advance!
geralu
6 Jul 2024 15:12
Hello, for BRIMNES furniture I would recommend starting carefully with fine sandpaper to roughen the surface. Use water-based varnishes or oils for protection. For films/laminates, avoid using strong chemicals, as this can cause the film to peel off. An alternative is to renew the furniture film or paint with chalk paint.
LOGEMIN
7 Jul 2024 09:37
Sustainably restoring BRIMNES furniture requires careful planning, as the particleboard is coated with a plastic foil. Here is a simple step-by-step guide:
- First, thoroughly clean the surface – usually a mild all-purpose cleaner or vinegar water is sufficient. Avoid harsh cleaners, as they can damage the foil.
- If the foil is intact but worn, you can lightly sand it with fine sandpaper to create a surface suitable for applying a new, non-toxic water-based paint. Chalk paints work particularly well here and enhance the material’s reuse value.
- If the foil is damaged, carefully peeling it off is recommended. Soaking in warm water helps remove it without cracks or tears.
- Afterward, let the particleboard dry completely and treat it with an eco-friendly varnish or hardwax oil. Important: Applying wax allows the material to breathe and protects against moisture.
- For screws or fittings, oiling them with linseed oil or beeswax is advisable to prevent rust.
Common mistakes to avoid:
- Never use aggressive solvents
- Always sand evenly and gently
This method will extend the lifespan of your furniture, reduce waste, and promote a healthy indoor environment. Good luck with your restoration!
Josefane
7 Jul 2024 16:45
LOGEMIN schrieb:
If the film is damaged, carefully peeling it off is advisable. Soaking it with warm water can help remove it without cracks or tears.
A question regarding this: Are you sure that always removing the film is the best option? In BRIMNES furniture, the film is not just a protective layer but often serves as a bonding element to the particleboard. Removing it could compromise the material’s stability and potentially lead to more repair work. Sustainability often means altering the material as little as possible. Wouldn’t it be better to refurbish the film instead of removing it? After all, removing it creates additional waste and requires more resources for subsequent repairs.
It would be interesting to hear if anyone has long-term experience with removed films or if other sustainable methods might be more suitable without compromising the structural integrity of the furniture.
