ᐅ How can I sustainably repair Ikea HEMNES furniture?
Created on: 17 Mar 2021 09:17
manme
Hello everyone, I recently acquired some Hemnes furniture from Ikea that shows signs of wear and minor damage in various places. My goal is to repair these pieces as sustainably as possible so they remain durable and I don’t have to consider buying new ones right away. I’m particularly interested in which materials and tools are best suited, how to professionally fix common issues like scratches, chipped edges, or loose joints, and what repair methods make sense from a sustainability perspective. Tips for preventing further damage are also very welcome. Does anyone have experience repairing the HEMNES series or can offer specific advice on how to restore their solid wood furniture effectively and eco-consciously?
Laurence
17 Mar 2021 13:16
There are actually several different approaches for the mentioned types of damage. For scratches and dents on solid wood panels, you can use a steam method: place a damp cloth over the dent and gently iron over it so the wood swells and the dent lifts. Afterwards, lightly sand the area and treat the surface with a wood oil. For chipped corners, natural wood putty is ideal; it can be sanded smooth after drying and color-matched. For loose hinges, first check whether the screws are still firmly anchored in the wood – often it helps to remove the screws, fill the hole with some wood putty or wood glue, and then insert new screws. Be careful with veneered surfaces – avoid sanding too aggressively to prevent damaging the veneer. Instead, small surface damages are better concealed with wax or colored wax sticks.
nofomu
17 Mar 2021 13:42
For the chipped corner, you can attach small wood chips using wood glue and then refine the surface with fine sandpaper. Loosen the screws at the hinges, fill the holes with wood filler, and reinsert the screws. This will ensure stability.
rimole
17 Mar 2021 14:05
Scratches are best repaired using a wax stick designed for furniture. For dents, the steam method, as Laurence described, works well. You can fix any loose corners with wood glue, and then, if needed, touch up the area using a suitable repair kit.
KUDAISY
18 Mar 2021 09:11
A few additional tips to ensure a lasting repair: - Use products based on natural ingredients whenever possible (linseed oil, beeswax, water-based wood fillers). Avoid chemical bleaches, solvents, or harsh cleaners. - Minimize the use of power tools like orbital sanders unless absolutely necessary, as they create sanding dust and cause material loss. - When working with hinges, check if you can remove the metal parts to clean and re-oil them, which extends their lifespan. - To tighten screws, you can reinforce the old holes with wood glue and small wooden shims (wooden dowels). This keeps the wood stable and helps the furniture last longer. If you have any questions about specific products or procedures, I’m happy to help.
BEATE
19 Mar 2021 08:46
For most damage to Hemnes furniture, wood glue works very well if you fit the damaged parts together as precisely as possible. Scratches can be concealed with color-matched wax sticks or wood stains. Always check screws, as they often loosen due to the weight.
