ᐅ How can I sustainably renovate or modify my Ikea PLATSA furniture?
Created on: 3 Sep 2021 19:37
nebakin
nebakin
3 Sep 2021 19:37
I’m currently exploring ways to make my Ikea Platsa furniture more sustainable without having to replace it completely. More specifically, I’m looking for options to modify, refurbish, or customize this modular system so that it lasts longer, is more environmentally friendly, and has a unique appearance. I’m particularly interested in methods to enhance the surfaces (e.g., using eco-friendly paints or films), alternative materials for back panels or shelves, and how existing components might be repurposed for different uses.
I’m also curious if anyone has experience replacing the standard carcass panels with more sustainable alternatives, or how to make Platsa more durable when storing heavier items.
I’d really appreciate it if you could share your tips, guides, or ideas—also any common mistakes to avoid in projects like this.
Thanks in advance!
Leonardteo
4 Sep 2021 07:59
Your question about sustainably renovating or remodeling Ikea PLATSA furniture is very well formulated and addresses the key points directly.
Basically, there are a few important approaches:
- Surface treatment: Instead of harsh paints or varnishes, I recommend linseed oil or natural waxes. They provide protection and are environmentally friendly.
- Replacing the back panels: By swapping existing back panels with lightweight boards made from sustainable materials, you can reduce weight while using recycled content.
- Modular construction: The PLATSA modules are designed to be disassembled and reconfigured. This allows you to adapt them flexibly to changing needs, extending their lifespan.
- Additional reinforcements: If you need more load-bearing capacity, installing metal brackets or stronger shelf supports can help – they are easy to add and significantly improve stability.
- Upcycling old carcass parts: Other users have replaced doors with vintage wooden doors or handmade fronts to give the furniture a unique and sustainable touch.
It is important from the start to use secure yet detachable connections so you can remodel later. Avoid strong adhesives if you want long-term flexibility.
I’m happy to help with detailed questions if you have specific projects planned.
LOJOPAR
5 Sep 2021 10:41
Here are some structured tips regarding your questions:
1. Renewing the surface:
- Lightly sand the existing surface to remove older paint residues.
- Use solvent-free wood paints or stains that are free of harmful substances.
- For greater sustainability, natural waxes or oil-wax combinations are excellent as they keep the wood breathable.
2. Back panels and flooring:
- Instead of standard hardboard panels, you can use thin plywood panels with FSC certification.
- Sometimes cork is sufficient as a back panel—it’s a good option for sustainability and sound absorption.
3. Modifications:
- Continue using the same series of connectors, but also add smaller wooden strips or corner joints to increase stability.
- You can also disassemble existing PLATSA carcasses and rebuild them into a bench with storage.
4. Avoiding mistakes:
- Do not use permanent adhesives; otherwise, you will lose flexibility.
- Uneven surface preparation leads to poor durability of the new coating.
Summary: With a systematic approach and quality materials, you can significantly extend the lifespan and reduce the ecological footprint.
If you like, I can also create a small DIY plan for you.
nonpra
6 Sep 2021 18:22
LOJOPAR schrieb:
You can also take apart existing PLATSA carcasses and convert them into a bench with storage.
That works! I did it myself – just added a sturdier seat panel, installed hinges for the lid, and that’s it. Sustainable and practical.
