ᐅ How can I clean Malm furniture in an environmentally friendly way?
Created on: 27 Jun 2022 08:34
Narke
I’m hoping there are some experienced furniture owners here. I have several Malm pieces from Ikea at home and want to clean them as sustainably as possible, without using harsh chemicals or disposable products. Therefore, I’m interested in how you clean your Malm dressers and nightstands in a way that doesn’t damage the surfaces while still being environmentally friendly. Are there any special home remedies or care methods you would recommend?
The surfaces are melamine-coated, so not solid wood, and I’m concerned that some products might damage the coating. I’m really open to tips that are both effective and gentle. Thanks in advance!
Sinan-meo
27 Jun 2022 11:19
I’d like to add: timing is also important – stains should be removed as soon as possible. Especially with melamine-coated furniture, dried-in stains can be much harder to clean later.
Regarding sustainability: it’s better to use washable microfiber cloths instead of paper towels. These can be washed multiple times, making them a much more eco-friendly option.
To avoid scratches, never scrub directly with a sponge; always wipe gently and lightly. For greasy stains, I warm the water a bit, which often helps without needing harsh cleaning agents.
kogudra
27 Jun 2022 12:04
One more note on “sustainable” cleaning: I find it practical to always make cleaning products yourself, as this greatly reduces packaging waste.
For example, vinegar and water, baking soda for tougher stains (but use sparingly), and then simply wipe off. It is important that the mixture is not too harsh – this is the only way to protect the coating.
Long-term maintenance is also important: regularly dust furniture and avoid cleaning it too wet. This helps the protective layer last longer and reduces the need for frequent cleaning.
nonpra
27 Jun 2022 12:30
If stains stick, use a microfiber cloth with warm water and a little dish soap. Do not use solvents or bleach.
Dry quickly, otherwise the edges will swell.
Katan
27 Jun 2022 14:22
For those who like it practical: After cleaning, just wipe again with a dry cloth to restore that rich, well-maintained look to the surface. 🙂
By the way, I like to make the water cycle more sustainable. Save water drops, use a microfiber cloth damp rather than wet – and if vinegar is needed, dilute it well. That way, it not only feels clean but also really good for the environment. 😉
JAMESONB41
27 Jun 2022 15:56
For Malm, it is best to avoid oils or waxes. They do not absorb well and quickly make surfaces sticky.
V
Victor54
28 Jun 2022 08:12
kogudra schrieb:
Always make cleaning products yourself; this greatly reduces packaging.
That’s true, but you also need to consider the effectiveness: baking soda is great, but too much can damage the coating. A general recommendation isn’t helpful—you have to use it carefully.
For this reason, it’s also best to avoid mixing just anything arbitrarily. Does anyone here know of studies or practical experience with baking soda on melamine? I found very little reliable information on this.
