I own several IKEA Malm furniture pieces, especially dressers and nightstands, which unfortunately start to wobble or feel less stable after some time. The construction using particleboard and the typical cabinet design seem to weaken in certain areas, especially with heavy use or when heavy items are placed on them. Therefore, I’m looking for practical and as permanent as possible methods to stabilize these pieces again.
I’m interested both in simple repair tips for non-professionals and recommendations for materials or reinforcements that help strengthen the furniture long-term without significantly affecting their appearance.
Has anyone had experience with specific reinforcement techniques for Malm furniture or knows of products that have proven effective? Which weak points should I pay special attention to?
Thanks in advance for your helpful advice!
Hello Janfi62,
If I were you, I would first retighten all screws and connections. They often loosen quickly with particleboard. If the back panel is weak, it helps to reinforce it by attaching brackets at the corners.
Screwing a thin board inside the furniture as reinforcement makes it more stable without major modifications.
Good morning,
Regarding your question about how to stabilize Malm furniture, I would like to give you a somewhat more detailed and technical answer, as stability mainly depends on the construction and the load. Malm furniture is mostly made of particleboard, which works well for the affordable price and design, but the fastening mechanisms can give way under load.
First, carefully check all connecting elements (metal brackets, wooden dowels, screws) for play and wear. If the screw holes are worn out, it helps to fill them temporarily with wood glue and wooden dowels or toothpicks and then screw them back in.
Twisting or loosening of screws can be prevented by adding extra metal brackets or even small metal plates inside the joints – this especially improves stability on the side panels and back panels. For the back panel, it is often advisable to replace the thin cardboard or particleboard with a thin plywood panel fixed with somewhat stronger screws and brackets.
I would like to ask a few questions: Are the furniture pieces heavily loaded sideways? Are they moved frequently? Should the stabilizing measures be visible, or should the interior remain as unaffected as possible?
These details will help to recommend an appropriate solution.
TEBILO schrieb:
First, carefully check all fasteners (metal brackets, wooden dowels, screws) for play and wear.I fully agree with this and would like to add a step-by-step guide that often helps:
1. Completely empty the dresser and check each joint for instability, especially in the corners.
2. Tighten all screws firmly. If any screw holes are worn out, fill them with wood glue and, if necessary, wooden dowels to reinforce stability.
3. Reinforce the back panel if it is made of thin cardboard by replacing it with a thin, sturdy plywood or multiplex board (4–5 mm (0.16–0.2 inches)).
4. Install small metal brackets inside the corners to reduce wobbling significantly.
5. If the furniture still feels unstable, adding an extra wooden beam, for example a wood strip, either across or along the back, hidden from view, often helps.
Common mistakes when stabilizing DIY furniture are loose screws or overlooking the back panel, which is sometimes underestimated as a load-bearing element.
If you need more details, I’m happy to help.
