I recently bought some Ikea Platsa furniture and now I’m facing the issue of placing it stably on a slightly uneven floor in my apartment. The unevenness is not very large but noticeable enough that the furniture wobbles slightly or doesn’t stand perfectly.
I’m wondering what options are available, especially for PLATSA, which are modular and flexible pieces, to align them securely and permanently without causing damage or rocking later on. Are there specific leveling materials, modifications, or Ikea accessories that work well, or do you have personal tips on how to ensure stability on uneven floors?
I am open to all suggestions, whether DIY solutions, special feet, or other clever ideas you have tried in practice. Thanks in advance for your tips and experiences!
Sebastianm schrieb:
I would simply use furniture wedges that you clamp onto the legs.This is a quick fix, but for long-term stability, I would recommend adjustable feet instead.
Jakura schrieb:
I find the idea of furniture glides or adjustable feet interesting – are there specific models or attachment types that work particularly well with PLATSA?With PLATSA, you can unscrew the standard feet. It is advisable to use threaded metal adjustable feet. These replace the standard feet and allow for precise, millimeter-accurate leveling.
Additionally, I recommend using felt pads underneath to prevent scratches.
If your furniture is on a hard stone or tiled floor, rubber pads are also recommended for extra grip. Combined with wall mounting, this creates a stable and secure solution.
For stabilization, I simply used self-adhesive felt or rubber pads on my PLATSA furniture. This cushions uneven surfaces and prevents scratches.
Alternatively, small wedges placed under the feet are also effective and quick to install.
All in all: secure the furniture to the wall, replace or add feet if necessary, and use a wooden base for larger unevenness.
pikin schrieb:
From a technical perspective, it makes sense to improve the stability of PLATSA furniture on uneven floors as follows:Thank you especially for your clear and well-structured advice. The idea of a plinth construction and securing the modules with brackets is very interesting for my project, as I plan to stack several units on top of each other.
Could you please briefly explain which material thickness and type of wood I should consider for such a plinth, especially to keep it lightweight yet stable? Are standard 12 mm (half-inch) plywood panels sufficient, or should I use thicker ones?
The connection to the furniture with brackets also sounds good. Do you have any experience regarding which bracket shapes (L, T, U) are more suitable?
I want to avoid damaging the furniture through incorrect assembly, so thank you in advance for your expertise!
Jakura schrieb:
Could you briefly explain which material thickness and type of wood I should consider for a base like this, especially to keep it lightweight but stable?Plywood panels are very sturdy; 12 mm (½ inch) is usually sufficient for low loads. However, if you plan to stack several PLATSA modules, I would recommend 18 mm (¾ inch) to increase load-bearing capacity.
Jakura schrieb:
Connecting the base to the furniture with brackets sounds good too—do you have experience with which bracket shapes (L, T, U) are better?L-brackets are generally enough to attach the base to the underside of the furniture. For larger structures, a T-bracket can provide extra stability if the joint needs to secure multiple axes. U-profiles are usually more complex and better suited for specific applications.
Personally, I use galvanized steel brackets with sufficient thickness (at least 2 mm (0.08 inch)) to ensure a secure connection.
