I have some BILLY shelves from IKEA at home and want to set them up securely on carpeted floors. Since the floor is softer compared to, for example, hardwood or tile, I’m concerned that the shelves might not be stable enough or could easily tip over when loaded or when pulling items out or putting them in.
Are there specific measures or accessories to improve the stability of BILLY shelves on carpeted floors? I’m thinking of solutions like additional feet, plates, spacers, or other techniques that might help. Experiences with securing them to the wall in such cases would also be useful.
What tips do you generally have to prevent BILLY shelves from wobbling or tipping on carpeted floors? Thanks for your help!
Hello otto57,
to improve the overall stability of carpets, the main issue is the soft surface underneath. The shelf legs create point loads, which cause the feet to sink slightly and promote tilting.
I would recommend the following steps:
1. Foot enlargement: Use sturdy bases under the shelf legs, such as thoroughly dried MDF boards or thin plywood sheets, preferably rigid. These distribute the load over a larger area and prevent sinking.
2. Height adjustment: If the carpet surface is uneven, adjustable furniture feet can help – you can mount these under the legs or correct the height with wooden shims.
3. Wall fastening: This is essential for BILLY shelves, especially on soft flooring. Whether with metal plates or special wall brackets for carpets, securing the shelf to the wall prevents tipping when pulling out books.
4. Additional fixing: For very thick carpets, it’s possible to create space beneath the carpet for a sturdy wooden board, provided the carpet height allows it.
Quick question: How thick is your carpet approximately? This is important to choose the appropriate height for the bases.
I recommend following these steps as precisely as possible, as this is really about exact levelness and load distribution. Otherwise, the shelves will wobble eventually despite all efforts.
Palenar schrieb:
Just a quick question: How thick is your carpet approximately?The carpet is about 1.5 cm (0.6 inches) thick, fairly densely woven, but definitely softer than, for example, a thin runner. I have actually noticed some issues where the shelves tilt or wobble slightly depending on the load.
lisku schrieb:
You can place small MDF or wooden boards under the legs to increase the pressure area.That sounds really good, I do have MDF boards here, so I could make suitable cuttings.
Palenar schrieb:
Wall mounting is an absolute must for BILLY shelves.What is the best way to fix the shelves to the wall when the carpet slightly changes the distance to the wall? Should something be placed under the bottom shelf before screwing in the brackets?
Thanks already for the tips!
Hello otto57,
I would like to address this topic in detail. Installing BILLY shelves on carpeted floors can be tricky because the soft surface increases the risk of tipping. To ensure the shelving unit stands securely, please consider the following steps:
1. Base support: The previously mentioned MDF or plywood boards are ideal. It is important that these boards match the exact dimensions of the shelf feet’s base or are slightly larger. This ensures the weight is distributed evenly.
2. Height adjustment: Carpet thickness can affect the distance to the wall. Therefore, it is advisable to install the boards so that the shelf base rests flush against the wall.
3. Wall attachment: It is best to use the included metal brackets from IKEA. Attach these to the back of the shelf just above the top shelves, then secure them to the wall to prevent any movement.
4. Protective measure: You can also apply self-adhesive felt pads between the wall and the shelf base to compensate for minor unevenness and protect the wall unit.
5. Finally, check the stability of each individual shelf for tipping.
The key is the combination of all these measures. MDF boards alone cannot fully stabilize the system. Also, be sure to regularly re-tighten the screws, as wood can shift under load.
One question: How tall are the shelves, and how heavy is the load (books, decor, etc.)? This greatly affects the choice of base support and attachment method.
Filippo schrieb:
One question: How tall are the shelves, and how heavy is the load (books, decor, etc.)?The shelves are 202 cm (about 79.5 inches) tall, so the standard version, and fully loaded with books. The load is estimated at around 30–40 kg (66–88 lbs) per shelf, fairly evenly distributed across multiple rows of books.
I plan to use a flat wooden board as a base and secure the shelf with the existing IKEA wall brackets.
Thanks for the explanation—very helpful to consider the wall clearance factor!
