ᐅ How can I stabilize Billy shelves if the floor is uneven?
Created on: 1 Sep 2020 08:37
Lireon
I recently bought several Billy shelves and want to set them up in my home office. Unfortunately, the floor in that room is quite uneven – there are slight waves and minor height differences, so the shelves don’t stand very stable and tend to wobble.
My question to you: How can I stabilize Billy shelves when the floor is uneven? Are there proven methods or materials to improve their stability without damaging the shelves themselves? I’m looking for simple and practical solutions that will last in the long term, as I use the shelves for books and work materials.
I look forward to your tips and experiences!
letar
2 Sep 2020 08:43
From a technical perspective:
If the floor is uneven, point loads can occur at the base supports of the shelving units, which can cause wobbling and, in the worst case, damage to the floor or the shelf feet. The optimal solution is to increase the contact area and compensate for the unevenness.
Adjustable furniture feet are useful because they can be screwed directly to the shelving unit and are height-adjustable. Alternatively, thin furniture wedges, preferably non-slip versions made of rubber or plastic, can help.
Some users combine both: a flat base made of plywood or MDF, with adjustable feet or wedges underneath. This approach is especially effective for larger unevenness.
For added safety, I strongly recommend securing the shelves to the wall, as Billy shelves can tilt under load regardless of floor evenness.
Tatovin
2 Sep 2020 09:01
As others have already mentioned, adjustable furniture feet are the best option.
Additionally, I try not to place the feet directly on the floor but instead put a non-slip mat underneath. This way, everything stays more stable and doesn’t wobble.
jokau
3 Sep 2020 14:56
Secure the shelf to the wall and use furniture wedges. I use plastic wedges, which hold well and cause no issues.
GALENKU
4 Sep 2020 06:45
I placed wooden shims under the shelves in my uneven room and secured everything with wall brackets. Since then, everything has been stable and steady.
BeAndrea
4 Sep 2020 08:20
Finally, I want to emphasize once again that securing shelves like Billy to the wall is always recommended, even if the floor is completely level. Regardless of any unevenness, this prevents the shelf from tipping over, which is especially important when children or pets are around.
The best combination is adjustable feet, furniture shims for fine leveling, non-slip pads, and definitely wall fastening. This way, you’ll be on the safe side. Good luck!
