ᐅ How can I speed up the assembly of the IKEA Brimnes furniture?
Created on: 25 Apr 2021 19:37
Mirza
Mirza
25 Apr 2021 19:37
Hello everyone, I recently bought an IKEA Brimnes sideboard and am now facing the assembly project. Since I want to assemble the sideboard as quickly and efficiently as possible, I’m wondering: What approaches, methods, or tools would you recommend to significantly speed up the IKEA Brimnes assembly without compromising the quality or stability of the furniture? Are there any specific tips on how to avoid common pitfalls or ensure a structured process? I look forward to your experiences and advice!
kemads46
25 Apr 2021 20:12
Hello Mirza, I’m happy to provide you with a simple step-by-step guide that will really make the Brimnes assembly easier and faster:
- First, sort all the parts and screws, preferably on a large, clean surface. This helps avoid long searches in between.
- Read through the instructions completely once to understand the individual construction steps. Delays often happen when you get stuck at one point because you didn’t fully grasp the next step.
- Prepare your tools: a Phillips screwdriver (preferably electric with adjustable speed) will speed up the screwing process significantly.
- Group parts according to construction phases, which minimizes switching back and forth.
- Important: don’t fully tighten the screws immediately—only do so after all parts of the current phase are assembled. This way, you can still make adjustments if needed.
You can usually avoid typical mistakes like mixing up drill holes or twisting side panels this way. If you want, I can also share specific tips for tricky spots.
Saramar
25 Apr 2021 21:04
Faster assembly means: Use a cordless drill with adjustable torque.
- Lay out all screws and parts in advance.
- Place the instructions directly next to the workpiece.
- Work systematically step by step, instead of assembling parts half-heartedly.
This saves time and frustration.
moses
26 Apr 2021 08:56
I know the feeling when you’re sitting in front of a piece of furniture and it just takes forever. I completely understand your question: assembly often causes more stress than enjoyment. What I’ve learned to do, besides carefully sorting the parts, is to plan breaks well. I’ve noticed that when I rush, I make mistakes or lose focus.
Also, I’ve learned that you shouldn’t apply maximum torque to every screw, even if it might loosen things up—that can cause damage, which ends up costing more time.
I also find that having two people usually makes assembly more relaxed and faster. If you have someone to help, let them prepare the parts or locate the spots—that saves time and boosts morale.
In general: It doesn’t help to focus only on speed if you end up having to start over. For me, quality and speed should go hand in hand.
dunitan
27 Apr 2021 14:22
kemads46 schrieb:
First, sort all parts and screws, preferably on a large, clean surface. This way, you avoid spending a lot of time searching during assembly.
This is a very important tip that I also agree with. I would like to add a bit more detail. Preparation is key:
- Check the parts against the instructions to make sure nothing is missing; small packaging damages will also become immediately apparent this way.
- Pay special attention to the correct sequence during assembly, as the manual is often optimized for stability.
- Having an extra pair of hands is invaluable – it really helps when holding and positioning parts.
- Tools: Keep a small cordless screwdriver as well as a regular screwdriver within reach.
Some additional tricks:
- Use labeled containers (cans or boxes) for different types of screws to keep an overview at all times.
- Watch videos or picture instructions in advance, if available; this can reduce uncertainty and prevent mistakes during assembly.
I hope these tips help you! Take your time—it usually pays off.
