ᐅ How can I speed up the assembly of the wardrobe using Ikea PLATSA?
Created on: 12 Jun 2022 18:42
Nama55Hello everyone,
I recently purchased several IKEA Platsa cabinets and want to assemble them as efficiently as possible. Since the system consists of many individual parts and the instructions can be somewhat detailed, I’m wondering: How can I speed up the assembly of IKEA Platsa cabinets without compromising stability or quality?
I am considering whether there are specific steps or tools that save a lot of time, or if it is worthwhile to optimize the order of assembly. Perhaps some of you have experience with assembling multiple units simultaneously or tips for handling the connectors.
I understand that some precision is necessary, but any efficient method would help, as I need to build several cabinets in a row and would like to reduce the workload.
Looking forward to your experiences and practical advice!
Rashadmeo12 Jun 2022 19:07Hey Nama55,
really great that you’re approaching it this way! ✨ From my own experience, I can say that with the right preparation, you can save a lot of time! Here’s my tip:
- Lay out all the individual parts beforehand, preferably sorted by assembly step.
- Use a cordless drill with the appropriate bit so you don’t have to keep changing the attachment.
- If you have someone to help, aligning the cabinet carcasses goes much faster.
I also think it’s important to read the entire manual first, complete the first cabinet fully, and only then start with the others. This helps prevent mistakes!
Give it a try, you’ve got this! 💪🙂
Rashadmeo schrieb:
Use a cordless screwdriver with the appropriate bit so you don’t have to keep switching attachments.That’s a good start, but I’d like to add some more detailed points that can save significant time, especially with PLATSA:
- Preparation of fasteners: Sort all screws, dowels, and connectors by type and assembly step before you begin. A small tray or magnetic box helps prevent picking the wrong piece.
- Multiplex screws vs. manual screwing: Using a cordless screwdriver with a torque limiter avoids over-tightening the relatively thin panels.
- Understand the assembly system better: PLATSA often uses a cam lock connector system, meaning the holes are pre-drilled but alignment must be precise. Any misalignment leads to time-consuming adjustments.
- Parallel assembly: When assembling multiple cabinets, build the carcasses separately until they are securely stable, then install doors or interior fittings. This divides the assembly process and avoids constant repositioning.
Feel free to ask how many modules you have and which rooms they are for, so we can give even better advice.
Nama55 schrieb:
How can I speed up the cabinet assembly with IKEA PLATSA without compromising stability or quality?Additional advice:
- Use a cordless drill with adjustable torque to prevent damage to the panels.
- Sort and label each component according to its position in the cabinet system before starting.
- Work in clearly defined stages: first the carcass, then the back panel, followed by the doors and interior fittings.
- If possible, have helpers assist with aligning and securing large modules.
- Be careful not to overtighten screws and joints, as the engineered wood materials are relatively thin.
This systematic approach not only saves time but also reduces errors and rework.
