ᐅ How can I speed up the assembly of the IKEA BRIMNES furniture when I have limited time?
Created on: 1 Jul 2021 10:37
emirhan48
emirhan48
1 Jul 2021 10:37
I am currently facing the challenge of assembling the IKEA Brimnes wardrobe, but I have very limited time available. My question is: How can I speed up the assembly of the IKEA Brimnes when short on time, without compromising on quality or stability?
I am familiar with the basic steps and have the necessary tools ready, but I am mainly looking for tips on preparation, the best approach, and possibly shortcuts that are truly effective.
I would appreciate it if you could share your experiences and recommendations – including advice on what should definitely not be shortcut to ensure everything remains safe and sturdy in the end. Thank you!
Guyju
1 Jul 2021 11:12
Hello emirhan48,
Your concern is very understandable. IKEA furniture, like the BRIMNES wardrobe, is modular and straightforward in design, but assembling it can still be quite tedious, especially under time pressure.
Here is a structured guide to help you work efficiently with a clear plan:
- Preparation: Go through the entire contents of the package and sort all parts by size and function. This saves searching time during assembly.
- Gather tools: Screwdriver, hammer, possibly a cordless drill with the appropriate bit. This will speed up screwing tasks.
- Read the instructions: Don’t just read the first page; skim through all the steps to get an overall understanding.
- Divide the work: If possible, ask someone for help. Holding the panels can save a lot of time.
- Screwing: Initially tighten screws by hand until all parts are in place, then fully tighten them. This allows quick corrections if needed.
Important: Don’t be tempted to skip essential parts of the instructions or to screw parts together without proper alignment. This often leads to more time spent fixing mistakes or results in an unstable wardrobe!
In summary, careful preparation and a thoughtful approach are the most effective ways to save time without compromising quality.
Feel free to reach out if you have any further questions!
nonpra
1 Jul 2021 13:43
My recommendation: First clear your workspace so you don’t waste time searching.
Then sort all screws and wooden parts by type.
Use a cordless drill, but don’t tighten too much.
And follow the instructions step by step.
nedagla
2 Jul 2021 09:05
Hey emirhan48,
don’t stress! 🙂 The BRIMNES can be a bit tricky, but with a few tips, it’s definitely doable – even if you’re short on time!
Here’s my experience: Before you start assembling, create a playlist with your favorite music to make the process more fun and faster! 🤩
Also, if you find the instructions frustrating, take your time to carefully study them the first time around so you don’t have to go back later.
A little trick that helped me: Have all the screws ready for each step before you begin tightening them. This saves you from constantly looking for them.
Keep your chin up, you’ve got this!
flo-Theres
2 Jul 2021 15:28
Guyju schrieb:
Important: Don’t be tempted to skip or screw parts together without properly aligning them, especially in crucial sections of the instructions.
This is an important point I want to emphasize. When assembling IKEA furniture, it’s common to save time by putting parts together too quickly – but this often leads to fitting issues or damaged components.
Additionally, I recommend checking the fit of the edge banding on the BRIMNES before tightening everything. Incorrect alignment can cause significant problems later when installing the doors.
Another tip: work on a sufficiently large, flat surface. This helps avoid warping and makes it easier to put the parts together, saving both time and frustration.
Finally, if you’re short on time, it’s better to invest more effort in preparation than to rush the assembly, as mistakes always end up costing more time later.
