I recently bought several Billy bookcases from IKEA and was wondering if there are effective ways to speed up their assembly. I am particularly interested in how to reduce the assembly time without compromising the stability or proper alignment of the shelves.
While I do have experience with furniture assembly, I would like to become more efficient—there might be tried and tested tips or tricks beyond the included instructions.
I usually assemble the furniture alone and am wondering if it’s advisable to approach certain steps differently or if any special tools are recommended to complete the job faster.
Who among you has practical experience assembling Billy bookcases and can share insights to help me significantly cut down my assembly time? Thanks in advance!
I would like to add: If you tension the back panel, you can install a cross screw in one corner that you can loosen later.
This allows you to adjust the shelf slightly during assembly and tighten the screw at the end. This helps prevent tensions that often cause warping.
Temporarily attaching the shelves with just a few screws also helps with alignment.
One final tip from my experience: avoid working hastily, even if you want to speed up.
A structured, calm approach prevents mistakes that will cost you time in the end. If you notice yourself getting nervous, it’s better to take a short break.
With a clear mind, everything goes more smoothly. Wishing you continued success!
