ᐅ How can I deal with unexpected issues when assembling IKEA Hemnes furniture?
Created on: 14 Dec 2021 18:37
BETUSIHello everyone, I would like to start a discussion about an issue that often causes me frustration when assembling IKEA Hemnes furniture: How can unexpected problems during assembly be resolved? Usually, I can follow the included instructions well, but unexpected difficulties frequently arise, such as incorrectly fitting dowels, unexplained misalignments, or partially missing drill holes. I am particularly interested in practical and reliable solutions you know to overcome these obstacles without compromising the stability or appearance of the furniture. Who has had similar experiences and can share tips on how to handle these challenges when assembling Hemnes furniture?
draFrederi14 Dec 2021 19:03Hey, great question! Hemnes is really great, but sometimes assembling it feels like a nightmare puzzle, right? 😅 My rule of thumb when something doesn’t fit right away: Take a deep breath and don’t force anything. If a drill hole or a dowel seems misaligned, it sometimes helps to gently smooth the edges with some fine sandpaper or a file so everything fits together nicely. And if a part just won’t fit, double-check that you’ve matched all the components correctly—Hemnes can offer more variations than you might expect. Stay calm; that helps more than getting frustrated. 😉
I agree that proceeding carefully is important. Additionally, I recommend always checking the screws and fittings for completeness and quality before starting the assembly. Problems with the Hemnes system often occur when screws are slightly damaged or bent. If a hole is not exactly aligned, a thin drill bit can help adjust the position slightly. It is essential to work slowly and carefully to avoid compromising stability. It is also important to use hand tools such as a good cordless drill with torque control to prevent overloading the material.
draFrederi schrieb:
If something doesn’t fit right away: first take a deep breath and don’t force it tight.I think this advice is often taken too lightly. Many people lose their patience and force the parts together, only to find out later that the furniture is actually damaged. Hemnes is decent enough, but the construction is not a designer piece that has to fit perfectly down to the millimeter. Sometimes a small deviation is normal and should be expected. So instead of trying to fix every mistake with a drill or a sander, it’s better to ask yourself whether the assembly really makes sense — before losing your ceiling or your nerves.
Leonardteo15 Dec 2021 15:12An important aspect not to be underestimated is thorough preparation. I recommend sorting all parts before assembly, reading the instructions step by step, and paying special attention to critical installation points. For Hemnes, it can be helpful to use additional small wooden strips or double-sided tape to hold parts in place before screwing them together. Even with minor fitting inaccuracies, wood glue works very well as it provides extra stability and eliminates small gaps.
