ᐅ How can I simplify the assembly of the Ikea Brimnes furniture?
Created on: 5 May 2019 08:17
Brigitte33
Good morning everyone, I recently purchased the Ikea Brimnes wardrobe and am now preparing to assemble it. Since the piece includes quite a few parts and some complex steps, I would like to know if you have any tips on how to simplify the assembly of the Ikea Brimnes. I am especially interested in advice on useful tools, practical preparation steps, and possibly tips on how to better organize the assembly process to avoid mistakes or delays. I appreciate any suggestions or experiences, as a systematic approach is important to me. Thanks in advance!
TYRELL
6 May 2019 07:44
Hello Brigitte33,
Brigitte33 schrieb:
Chipboard panels are well known, but with previous furniture I sometimes had issues with screws not holding properly or parts that could easily splinter.
It is important to screw in slowly and apply moderate pressure. I recommend starting with a cordless drill on a low speed setting. Also, a useful trick is to pre-drill the holes with a thin drill bit before screwing, if they are not already pre-drilled. This reduces the pressure on the material, minimizes splintering, and helps the screws hold more securely.
Additionally, make sure to drive the screws straight into the material without angling them, as this improves the overall stability.
Would you like me to explain exactly which screws are particularly critical for which parts?
Brigitte33
6 May 2019 08:31
TYRELL schrieb:
Would you like me to provide a detailed explanation of which screws are especially critical for which parts?
Yes, I would really appreciate that! Especially because I want to avoid the cabinet losing stability when screwed together or connections not holding up over time. Thank you for the offer.
TYRELL
6 May 2019 09:02
Gladly.
For the Brimnes, the connection between the side panels and the bottom panels is particularly critical. Longer chipboard screws are usually used here to support the weight. Make sure the screws are properly seated and not driven in too deep, as this can cause the wood to compress too much and weaken the hold.
When attaching the back panel (usually a thin MDF board), shorter screws or nails are common – apply only light pressure here since the back panel primarily provides stability and does not bear load.
Doors and drawers require special care with the fittings: screws should fit snugly but not be over-tightened to avoid damaging the material. After assembly, check the opening and closing – if it sticks, a slight adjustment of the screws may help.
What tools do you have available? Would that be helpful for further advice?
Brigitte33
6 May 2019 10:15
TYRELL schrieb:
What tools do you have available? Would that be helpful for further tips?
I have a standard cordless drill with various bits, a hammer, screwdrivers in different sizes, and a spirit level. Additionally, I was considering getting a torque attachment for the drill to better control the tightening. Would you recommend that?
Laurence
6 May 2019 11:04
Brigitte33 schrieb:
I have a standard cordless screwdriver with various bits, a hammer, screwdrivers in several sizes, and a spirit level.
This is a good basic set for assembling the Brimnes. I also recommend a torque adapter, as it helps prevent overtightening the material. Laurence can confirm that slow and careful tightening often works better than brute force.
Here’s a small tip: if possible, prepare a small bowl or box to collect all screws and fittings during assembly. This way, you avoid losing small parts or having them disappear when you rearrange things. It sounds simple but is very helpful, especially with multiple assembly stages.
