ᐅ How can I effectively expand Ikea Platsa cabinets?
Created on: 29 May 2021 17:43
V
Vendelinmi
V
Vendelinmi
29 May 2021 17:43
Hello everyone, I am facing the challenge of sensibly expanding my Ikea Platsa cabinets. The basic structure is already in place, but I want to make better use of the modular design to optimize storage space without negatively affecting the appearance or taking up too much room. The focus is especially on how to achieve more functionality through additional modules, clever interior fittings, or side extensions without the cabinet becoming quickly cluttered or losing stability. What experiences have you had, particularly regarding various usable expansion options such as shelves, drawers, or special inserts? How can typical mistakes be avoided when upgrading moderately, and which additional elements complement the cabinet best to create an organized and practical setup? Looking forward to your knowledge and tips!
jotisi
29 May 2021 18:52
An exciting topic, especially when considering how often Ikea Platsa cabinet systems are underestimated.
Vendelinmi schrieb:
It’s mainly about how you can gain more functionality through additional modules, clever interior fittings, or side extensions
I want to throw in a provocative statement here: The Platsa cabinet is only really expandable if you think completely outside the standard Ikea solution. What does that mean? I mean you shouldn’t just rely on the Ikea modules offered, but should definitely consider third-party modules, custom-made inserts, or modifications. Why? Because otherwise, you often end up with something generic and uniform. Many users just keep expanding the cabinet in the same way or fill it with standard boxes instead of really optimizing the use of space.
Especially for side extensions, I would even recommend working with custom-sized elements tailored to the Platsa carcass dimensions to avoid any gaps.
What I’m still not quite clear about, and I’m addressing this to everyone here: Who has experience with the stability of larger assemblies? Especially when adding overhead cabinets or placing multiple carcasses side by side – does everything become unstable relatively quickly?
Tevin
29 May 2021 20:31
Hello everyone, I would like to bring a bit more structure to the discussion, especially for those who are new to the Ikea Platsa system and its expansion options.
First, a few basics: Platsa is very flexible due to its modular design. The cabinets are usually 40cm (16 inches) deep (or sometimes 60cm (24 inches)), height varies depending on different carcass constructions, and width depends on the modules.
Important points for meaningful expansions are:
- Check the maximum load capacity of each module to avoid tipping over.
- For more storage space, adjustable shelves should be used, which can be distributed flexibly according to the area of use.
- Drawers or inner drawers provide great organization and accessibility, especially in deep cabinets.
- Side expansions can ideally be realized with additional carcasses from the Platsa range, as these fit perfectly together and the fronts also match in color.
- Sometimes it is worth supplementing inner fittings from other systems (e.g., VARIERA inserts), because these are often compatible and help create additional order.
Additions like mounted shelves or wall cabinets also increase functionality when room height can be utilized.
One more tip: If you value a consistent design, be sure to combine all fronts exactly and avoid mixing too many different series. Stability is gained through installed back panels and good anchoring to the wall. The Ikea Platsa cabinets offer several drilling points for fastening here.
I hope this helps as an overview for now. If anyone wants, feel free to discuss specific modules or combinations in more detail!
JAPLO
30 May 2021 08:18
jotisi schrieb:
Who here has experience with the stability of larger assemblies? Especially when adding wall cabinets or placing several carcases side by side – doesn’t everything become unstable quite quickly?
Basically, it can be said: Yes, the Platsa cabinet modules are stable on their own, but when placing several carcases side by side or stacking them, the responsibility for secure fastening increases significantly.
I recommend:
- Always use wall anchors or appropriate fixings, as specified by Ikea.
- When using wall cabinets, be sure to connect the carcases to each other, for example with the supplied connector strips.
- Distribute loads evenly and avoid placing too much weight on individual carcases.
Vendelinmi schrieb:
How can typical mistakes be avoided when doing a moderate upgrade
A common mistake is stacking without proper fixation. This leads to instability and often results in unused storage space because a cabinet can no longer be fully loaded.
Additionally, I recommend creating a plan or sketch in advance with the desired extensions to optimize measurements and space. The purchase of additional internal fittings should also follow this plan to avoid buying duplicate parts or ending up with modules that don’t fit together.
If these points are considered, you will enjoy the expanded Platsa system for a very long time.
